Camera interface with rockpro64
I am just about to buy Rockpro64 board. I am going to use Linux image on that. With that i want to have some camera applications such as Orbslam.
Please confirm which best camera should i use with Rockpro64. As i found few cameras which are either given to be supported with the Pin64+ level boards or with Android stock.
Thanks.
(09-24-2018, 11:19 PM)rahulsharma Wrote: Hi,
Thanks.
Did you see this listing on the store?
https://www.pine64.org/?product=rockpro6...dard-model
Yes i saw that. But it is givrn - Currently only stock Android build available, the community Linux build not yet support camera driver.
And i have said that i am going to use linux on it.
Thanks for the reply.
Yes i saw that link but there is given that the camera module is only supported for stock android version not for linux.
And i have said that i will be using Linux on my Rockpro64 board.
So please tell me the best camera that is supported on Rockpro64 board having linux OS.
Thanks.
It will be great if i get the confirmation asap:-).
Will Pine64 5 MP camera work with Rockpro64 camera? If yes then does it have Linux driver support?
Thanks.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,749 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,440 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,772 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,512 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,719 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,225 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,904 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,938 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,196 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 6,582 04-06-2023, 02:46 PM
