undocumented leads on rockpro64
What are the leads marked PWR, GND, REC, GND for next to the headphone/mic port?
(09-01-2018, 05:54 PM)Firesped Wrote: What are the leads marked PWR, GND, REC, GND for next to the headphone/mic port?
the REC should be "RES" and sorry on the typo. "PWR" is Power On Switch and "REC" is Reset Switch.
The four pins is the mirror to the reset and power on switches and allows developers, especially casing that has its own power and reset buttons to derive out these two signals. Original plan to put a connector there but worry about block with PCIe card. you may ask where put the connector on this place that knowing may block PCIe card, the answer is layout engineer already runs out of idea on the suitable place.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,714 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,403 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,725 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,472 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,676 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,177 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,864 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,843 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,163 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 6,543 04-06-2023, 02:46 PM
