Help needed Install Android using Mac OS X
PhoenixCard app is not really an option for me as the several computers I am running are all Mac OSX. I do have a netbook running Mint Linux. Looking for option that will work for the OS I have.  Also any specific Allwinner requirements might be helpful. I am comfortable with CLI and did a recent install of MintLinux with a formatted USB thumb drive from the Mac. Sure it is possible but need to be pointed in the right direction.
The one 'special' thing that PhoenixCard does (and that's why some people think it's a requirement) is adjusting the partition scheme to the size of the card where you want to flash the image to. Therefore without a Windows VM you're lost at the moment.
An alternative would be the Pine folks talking to their developers to implement a dynamic partition resizing mechanism on first boot and to provide an 4GB image that can be burned the usual way (WinDiskImager, Rufus, dd on Linux and OS X)
Interesting. Well my guess is that once set these partitions remain the same. There would have to be some sort of partition scheme for various sized disks. If I know what that is I could recreate it.
(03-23-2016, 05:35 AM)gubaguba Wrote: Interesting. Well my guess is that once set these partitions remain the same. There would have to be some sort of partition scheme for various sized disks. If I know what that is I could recreate it.
In images that have been posted, the partition to resize should be the last partition. The partition needs to be resized, and then the file system needs to be expanded to fill it. I believe there's already a script to do this on a running system, it's been posted somewhere in this forum.
(03-23-2016, 05:46 AM)benpope81 Wrote: In images that have been posted, the partition to resize should be the last partition.
Please do not confuse Linux with Android. There the data partition has to be adjusted and it looks like this (more or less, I neither know nor care whether Allwinner changed that with their Android 5.x builds or not): http://linux-sunxi.org/Android/partitions
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 3,574 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 5,129 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  PBP Debian 11 GRUB install error zlth 2 4,993 11-18-2022, 07:42 AM
Last Post: zlth
  wrong launguage install chadace 1 6,442 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 10,422 03-18-2020, 09:42 AM
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 26,690 05-15-2019, 02:55 PM
Last Post: Thatoo
Question Do I need a touchscreen to run Android? chrbar 3 8,618 08-08-2018, 10:55 PM
Last Post: chrbar
  Rock64 suitable for headless TVHeadend install? elsmandino 3 10,244 06-26-2018, 11:37 AM
Last Post: Luke
  ethernet lan speed problem android fulltone 0 4,040 04-23-2018, 01:47 AM
Last Post: fulltone
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,765 04-15-2018, 07:37 AM
Last Post: bunkerWHz
