xrdp problem with Rock64
i'm using a Rock64 with Xenial Mate (Ayufan), and after installing xrdp via apt (without problems), i try to connect to my Rock64 via RDP (using Remmina at other Linux machine or Rdesktop from a Windows laptop) and i get a login screen where i select XRDP or X11RDP, and after log in, just an empty blue screen. Nothing more, and amtpy desktop, without options, menus, etc...
What should i fix to make it work?
Thanks.
I suggest you upgrade to one of the newer images (running rdp on omv build without issues) https://github.com/ayufan-rock64/linux-build/releases
thanks for your reply. I have deleted my sd card and tried again the new versions you proppose (eactly bionic-lxde-rock64-0.7.9-1067-arm64.img.xz , 0.7.9, published 12 days ago), and it fails. I just "apt-get install xrdp", check it is running and then try to connect from a Windows machine with Remote Desktop to my Rock64 IP. It connects sucessfully, get a menu to choose the connection type (i try both, rdp and x11rdp) and after doing a sucessfull login, i get an empty and blu screen.
Am i doing it right? What can i do?
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 3,053 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 90,702 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,831 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,553 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,695 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,651 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,577 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,756 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 29,926 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,666 09-20-2024, 11:18 AM
Last Post: AwU2HBg
