Netrunner 18.03 Idolon for the Pinebook
#61
(06-01-2018, 04:54 AM)erchache2000 Wrote: I can use netrunner from sd and detects emmc but I don't know how to install on emmc.
I did dd if=/mmcblk0p1 of=/mmcblk1p1 without sucess...
I see I have mccblk0p1 for sd, and mmcblk1p1 for emmc, but appears too mmcblk1p1boot1 and mmcblk1p1boot0...
How I can fix it to use from emmc? O_o
I can solve it myself.
making a dd into emmc with image installer runs...
now trying suspend.
#62
Update:
We found the issue why standby and restore is not working for everyone.
Basically our script which resets the display (dpms off and dpms on basically) tries to search for the username (to execute dpms off and on) and assumes that it is loginctl session c1 always. This is however not always the case and therefore fails in all other cases.
Ultimatively this needs a fix in the driver itself as it should take care of it and we should not have a workaround script.
#63
(06-07-2018, 11:20 AM)leszek Wrote: Update:
But is there a workaround script available? Based on how Arm and Allwinner have worked on issues in the past, we probably won't have a fix for a VERY long time. Or am I misunderstanding something?
#64
Quote:But is there a workaround script available?
It is not publicly available yet.
#65
I think most people with the pinebook would be willing to take a look at it and test it out, i mean, it's a dev board in a laptop case after all. We all knew what we were getting when we bought it. I'd rather not wait months on a driver fix that may not ever come because it's closed source.
#66
You can find the updated script (meant to be as a temporary workaround) here: https://github.com/netrunner-pinebook/ne...eep/screen
Just replace the content of your /lib/systemd/system-sleep/screen file with it and it should work. (You need root rights)
#67
Does it work?
#68
I had to dismantle my Pinebook in order to get the emmc out and flash it, but on boot it worked quite well. Impressive work, gentlemen.
#69
I tried that, but it does not work. After first closing and opening the lid and unlocking the computer the sound does not work anymore, even after restart.
#70
WOW, excellent work, think I have found the distro that makes the pinebook fit for everyday use. KDE is my usual desktop on my other systems (KDE Neon) and to have plasma,
I know its early days, but any chance of latte-dock in the netrunner repo?
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 3 12,168 11-28-2025, 07:38 AM
  DietPi OS for Pinebook MichaIng 3 13,399 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 90,858 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 4,424 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 3,352 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 12,375 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 6,976 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 8,850 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 9,588 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 7,249 01-20-2021, 11:18 AM
