New User - No image file in LibreELEC download
Been trying for two hours to sort this out. (Using Windows7 64 bit to copy to SD Card)
I followed the link to the github page and downloaded libreELEC.tv-archived-re-leia24.zip file. (it was top of the list with the most recent date but there sre no instructions at all on github for noobs)
I extracted it using 7-zip into its own folder on my hard drive.
I have formatted my 16Gb SD card. I downloaded Etcher.
When I try to copy the image there is no .img.gz file. (Like I had for my RPi3)
I have tried downloading the tar.gz and extracting that to the folder but nothing recognised by etcher appears.
Can anyone tell me where I am going wrong?
Thanks in advance for any help.
(06-09-2018, 02:47 PM)Frogmella Wrote: When I try to copy the image there is no .img.gz file. (Like I had for my RPi3)
Is there a *.img file?
What is the URL of the file you downloaded?
you downloaded here ? https://github.com/Raybuntu/LibreELEC.tv.../rb-leia24
Thats not an IMAGE its just the SOURCE (as it says Source code (zip)) so you CANT Flash this on the SD card.
For the LibreELEC images use one of this links:
http://test.libreelec.tv/
http://kwiboo.libreelec.tv/test/
The Kwiboo images, fixed an error where you get blackscreen after you stop a video / a video ends. That is still now in the images on "test." (at least not in the version from 08.06)
(06-10-2018, 02:10 AM)gigagames Wrote: you downloaded here ? https://github.com/Raybuntu/LibreELEC.tv.../rb-leia24
Thanks very much. It seems the Pine64 website is linking noobs to the wrong place.
As you can see I'm no linux expert I just want to use the Rock as a media centre.
Kwiboo seems to have exactly what I need.
Do I need the .tar file as well as the .img.gz?
Thanks for that gigagames. Means the wiki needs to be updated, as the below is not correct then.
(06-10-2018, 02:33 AM)Frogmella Wrote: Do I need the .tar file as well as the .img.gz?
Unlikely, it's probably the same image just compressed two different ways... I would think you only need the img.gz file.
I'm just updating that wiki entry now since it's obviously wrong or out of date.
Unfortunately that revised link is for a release that crashes the Rock64 if you stop a video stream. It also crashes if you try and use the search facility in an AddOn.
Can anyone direct me to a link for a stable 17.6 Kryton image for the Rock64?
Thanks again.
@Frogmella as i sayd "The Kwiboo images, fixed an error where you get blackscreen after you stop a video / a video ends. That is still now in the images on "test." (at least not in the version from 08.06)" So download from http://kwiboo.libreelec.tv/test/ the LibreELEC-RK3328.arm-9.0-devel-20180606204626-0267cea-rock64.img.gz and you good to go
What do you mean with "search facility"
And the img.gz -> is the image
the .tar is for updating with the Update folder (if samba is activ you just can download it on you main pc drop it in the update folder and restart)
(06-10-2018, 01:13 PM)gigagames Wrote: @Frogmella as i sayd "The Kwiboo images, fixed an error where you get blackscreen after you stop a video / a video ends. That is still now in the images on "test." (at least not in the version from 08.06)" So download from http://kwiboo.libreelec.tv/test/ the LibreELEC-RK3328.arm-9.0-devel-20180606204626-0267cea-rock64.img.gz and you good to go
the .tar is for updating with the Update folder (if samba is activ)
Thanks for your interest but I tried Kwiboo first, it was unstable so I tried the other one and that was even worse.
The search facility is when you use an addon with the facility to search for the stream you want to watch. Do that (at least on the two main add ons I use) and firstly no results are returned, then the system locks, then it crashes.
I simply didn't realise that there was no stable LibreELEC for the Rock64 or I wouldn't have bought it.
I'm going to try to install Android for the time being and add Kodi from the play store until the LibreELEC issues have been ironed out (if ever they are).
One guy on the LibreELEC forum said that LibreELEC may NEVER be stable on the Rock64 as its development is purely experimental at the moment.
@Frogmella "search facillity" like in the youtube plugin for searching a video ?
test & kwiboo works for me stable, youtube, netflix, 1080p60fps videos.
But i have installed it on an eMMC card. If you have an eMMC card, try to installed it on there, it can be an problem with you SD card (maybe to slow)
If you doint have an SD card. Install u-Boot and install LibreELEC on an USB stick.
(06-11-2018, 08:41 AM)gigagames Wrote: @Frogmella "search facillity" like in the youtube plugin for searching a video ?
The search facility in Placenta and Neptune Rising addons was non-functional and caused a crash. There were other problems too.
I have now installed Android and downloaded Kodi from the playstore, seems to work fine that way so far although I hate having Android on the board.
I'll keep an eye on developments and may try LibreELEC again in a couple of months.
Thanks for taking the time to respond:-))
  Libreelec Rock64 - 4GB no boot spiker15 3 8,128 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Download IDB fail when trying to flash Android image cherkasoff 0 8,916 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Hoe to Update Buildroot Package config from SDK build.sh file shivarj89 0 3,243 09-09-2019, 09:39 AM
Last Post: shivarj89
  Download RetroPie for your Rock64 CiniCraft 3 10,392 06-01-2019, 08:02 PM
Last Post: x79ftw
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 177,506 02-06-2019, 04:02 PM
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,622 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 3,854 02-04-2019, 07:36 AM
Last Post: LMM
  HW image transitions in Python gaggleoxfoggy 7 13,427 11-24-2018, 10:41 AM
Last Post: gaggleoxfoggy
  Enable I2C, I2s, SPI in boot-config file? HelgeMK 3 11,912 08-14-2018, 10:59 AM
Last Post: pas059
  how to upgrade stock rom 8.1 on XZ file dhruan 4 9,395 07-05-2018, 11:15 PM
Last Post: dhruan
