Got your PINE64 board yet? Post here!
#41
(03-18-2016, 06:14 PM)rakib-hasan Wrote: @lzto Could you please share your reward/pledge details? Also, did you get any tracking info?
Yes, I am a early/February backer.
I pledged 1GB board without adding other accessories when filling the survey.
My tracking info shows that the package was shipped March 8, 2016 , 7:07 pm and it was delivered March 18, 2016 , 11:14 am.
#42
Congrats on receiving your board! What do you plan on doing with it first?
#43
I am compiling the kernel and bootstrap debian aarch64 on it. probably will do some benchmark next.
#44
Got mine earlier! No dents or damages on the package. Will try to boot it later when I get my power supply.
Sent from my LG-D852 using Tapatalk
(03-19-2016, 11:05 AM)stibc Wrote: Got mine earlier! No dents or damages on the package. Will try to boot it later when I get my power supply.
It seems a little bit bent on the first image
#46
I noticed that as well in the picture...it's mainly in the middle though
#47
I received mine as well, with just an ever so slight bend just like the photo, which I think should be fine...?  Everything are sticking to the board well except for the IR receiver being loose from the board. Anybody else with the same situation?  Is it easy to tighten?  Solder it I assume.  Sorry for being a newbie. First time with SBC stuff.
#48
U can just plug the Ir receiver in the headers ( if the pinout matches)
Or just make a cable to fit in there
Also if u want to be the Ir receiver fixed in the board u can solder It
Sent from my HUAWEI Y530 using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
#49
(03-22-2016, 12:12 AM)keiothic Wrote: I received mine as well, with just an ever so slight bend just like the photo, which I think should be fine...?  Everything are sticking to the board well except for the IR receiver being loose from the board. Anybody else with the same situation?  Is it easy to tighten?  Solder it I assume.  Sorry for being a newbie. First time with SBC stuff.
Tllim already explained this somewhere on this forum.
http://forum.pine64.org/showthread.php?t...R+receiver
"The IR receiver is not build into the Pine A64 board, so that other user who don't use the IR remote control function can use the same port for 1 wire protocol temperature sensor or security IC application.
... TL Lim
#50
It is March 22.  I do not see a single person who has received their board.  What is the status?
Question Is the PinePhone delivered to your door or to a post office? MirceaKitsune 11 20,567 11-22-2021, 11:58 AM
Last Post: zetabeta
  Didn't receive phone, no response from Pine64 at all rn43x 8 19,888 09-11-2021, 01:29 PM
Last Post: hacker
  New to Pine64: should I have expected a tracking number by now? Indieshack 2 8,417 06-19-2020, 03:44 PM
Last Post: Indieshack
  Earth to Pine64, please respond! EvanBeem 43 86,005 02-01-2017, 09:26 PM
  BEFORE You post asking about shipping from Pine Store (not Kickstarter) rahlquist 41 113,684 10-13-2016, 03:56 PM
Last Post: hans
  Pine64 sales are useless panoflex 1 6,470 09-22-2016, 06:06 PM
Last Post: pfeerick
  Pine64 2gb + stuff for sale or trade Caleb420 0 4,633 09-22-2016, 01:46 AM
Last Post: Caleb420
  Not Received Any Pine64 maheshsutariya 16 35,571 09-14-2016, 06:15 PM
  PINE64 ABS Playbox Enclosure be available for sale in the shop danlcarr 3 9,648 08-31-2016, 09:28 PM
Last Post: clocey
  Pine64 FS or Trade? birdcatx7 6 15,354 08-29-2016, 01:53 PM
Last Post: MarkHaysHarris777
