Power Supply ordering question
When the next batch of RockPro64's comes in I'll be ordering, but just had a quick question on ordering the ROCKPro64 12V 5A EU Power Supply, for people in the UK will this come with the a UK power plug lead or will I have to source this separatly ?
(05-19-2018, 08:00 AM)frewind Wrote: Hi,
Current we only supply US or EU plug. For UK, you will need to change to UK plug yourself.
Its a Two Pin "Very Large" wall wart, rather than a laptop 'brick' style kettle lead, So you will need a 2 pin EU to 3 Pin UK converter sadly.
(05-25-2018, 03:35 AM)boudiicca Wrote: Its a Two Pin "Very Large" wall wart, rather than a laptop 'brick' style kettle lead,  So you will need a 2 pin EU to 3 Pin UK converter sadly.
I have one of those, but this must present an issue when using the board for UK commercial projects.
Ouch. that won't go down well with some powerpoint socket types... Australia and the US spring to mind when using only two pins... it's going to loose that fight with gravity eventually!
Can I use a 5V power supply if I use emmc and USB HDD only (no sata) ?
Apologies for resuscitating an old thread ...
What is the allowable input voltage range for the ROCKPro64 through the barrel connector?
Somewhere I thought I saw a range up to 17V or more? With 12V recommended. But cant find it. I do have a 19V supply lying around but not the courage to try it without checking.
Didnt order a Pine PSU - had been using an ancient 12V 1.25A wart I had which went to meet its maker when I put a DVD on the USB3 Cool Managed to find another wart rated 12V 700mA which is doing OK but am now measuring power/volts etc and it is pretty much at spec with 100% CPU load so no bandwidth for any GPU or power sucking stuff plugged in elsewhere.
PS - found my answer - Pg 11 of schematic says 4.5V < VIN < 18V
(08-01-2018, 04:43 AM)dukla2000 Wrote: Apologies for resuscitating an old thread ...
Please only plug in 12V power supply to ROCKPro16 board especially when you have PCIe board and 3.5" HDD installed. The ROCKPro64 main board may able to handle higher than 12V supply but other plug in card or device that on 12V rail may not.
there are buck converters of good quality available for decent prices. i have bought some from amazon for less than $6us.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,727 05-28-2026, 05:29 PM
  Rock Pro 64 Won't power on matthewmkr 9 8,767 04-29-2025, 12:57 PM
Last Post: matthewmkr
  power button not working Vista8720 0 3,393 05-07-2024, 11:26 PM
Last Post: Vista8720
Question Another Fan Question backwoodstech2 1 4,507 02-03-2024, 04:09 PM
Last Post: backwoodstech2
  enble boot after power loss/restore dkebler 18 30,434 12-04-2023, 12:14 PM
Last Post: ok38
Information Question regarding odd startup behaviour Mff 0 3,894 12-03-2022, 03:18 PM
Last Post: Mff
  PCIE interface power on too late Slark Xiao 0 2,995 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Automatic power on after power outage gechu 1 5,987 11-17-2022, 06:13 PM
Last Post: acj_
  After Power Loss feature working bdherouville 2 6,017 08-22-2022, 03:52 AM
Last Post: bdherouville
  PWM fan control low power Connar 0 2,976 12-12-2021, 05:58 AM
Last Post: Connar
