How can I get a driver to support my USB wifi dongle
Just loaded my Rock 64 4G with Ayufan's Xenial desktop image and everything is working fine. I currently have it operating on a wired Ethernet connection. I plugged in my wifi dongle, an Edimax EW7318Ug but the Rock64 Xenial distribution does not appear to have a driver that supports it. On my PC version of Xenial I have in the past just added Linux Firmware Non Free to resolve this problem. This appears to be not possible in Xenial now.
I issued the lsusb command and this is the following output.
Bus 002 Device 002: ID 148f:2573 Ralink Technology, Corp. RT2501/RT2573 Wireless Adapter
The good news is the Rock64 recognises the dongle but I was wondering how I could go about adding a driver to support. I'd appreciate any help pointing me in the right direction here.
*I accidentally posted the original query in the Pine64 section but couldn't move it*
(04-17-2018, 04:56 AM)Rocklobster Wrote: Just loaded my Rock 64 4G with Ayufan's Xenial desktop image and everything is working fine. I currently have it operating on a wired Ethernet connection. I plugged in my wifi dongle, an Edimax EW7318Ug but the Rock64 Xenial distribution does not appear to have a driver that supports it. On my PC version of Xenial I have in the past just added Linux Firmware Non Free to resolve this problem. This appears to be not possible in Xenial now.
Hey, have you tried this?
I've seen that but a lot has changed on how drivers are loaded since 12.04. That's Kernel 3x and we are on Kernel 4x now. Linux Firmware Non Free was introduced to deal with the lack of proprietary wireless drivers in Ubuntu. That's seems to have changed too in 16.04.
Ayufans image doesn't appear to have support for older USB wifi devices but I may be wrong here. I don't want to start manually installing the wrong drivers and break the installation without being pointed in the right direction though thanks for the heads up.
Found this link but it looks heavy duty http://xman3141.blogspot.ie/2011/01/how-...r-arm.html
I'm wondering is this the route to go now.
I decided to go a different route and downloaded the Armbian image (test image for the Rock64) from armbian.com which supported Ralink "out of the box". I was also able to use armbian-config to configure the Rock64 (equivalent to raspi-config on the Raspberry Pi).
Everything is working fine now and I've got my home automation system up and running that was running on the Raspberry Pi. Very noticeable performance increase on the Rock64.
  1024x600 resolution support monte 1 5,799 03-14-2021, 11:32 PM
Last Post: monte
  Encryption support rockfun 1 4,729 06-10-2020, 08:27 AM
Last Post: rockfun
  mainline kernel sound support Openwrt lucize 2 7,121 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 11,692 04-18-2020, 11:34 PM
Last Post: CameronNemo
  on-board ethernet driver michaelanburaj 0 3,156 03-26-2020, 12:01 PM
Last Post: michaelanburaj
  gstreamer unable to process dvbsrc from ATSC tuner dongle grkblood13 1 4,785 08-31-2019, 09:01 PM
Last Post: grkblood13
  MSI-X support for KVM? pfworks 1 6,314 06-12-2019, 03:48 AM
Last Post: RussianNeuroMancer
  Hyperion/Ambilight support? qwasy 5 12,326 03-30-2019, 04:40 PM
Last Post: antaril
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,628 03-26-2019, 07:28 PM
Last Post: Poincare
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 6,896 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
