pine LTS with openBSD
Hi All,
I received the pine64 LTS board today and would like to load openBSD on to it. I have openBSD current snapshots running on a much older (from February 2016ish) pine64 board without any issues.
I did what I did last week to install openBSD on the working board:
sudo dd if=miniroot63.fs of=/dev/sdf bs=1M
Hooked up the serial connection, applied power and all I receive in the terminal is this:
U-Boot SPL 2018.03 (Mar 20 2018 - 04:43:06 -0600) DRAM: 0 MiB ### ERROR ### Please RESET the board ###
So what's it mean? Do I need to have the spi flashed with something? Does openBSD need to add support for this u-boot? Do I need an eMMC thing?
Here's the installation instructions for arm64:
https://ftp.openbsd.org/pub/OpenBSD/snap...TALL.arm64
https://www.openbsd.org/arm64.html
LTS is missing, but I do see this: "Pine64 Pine 64/64+" Is this separate from LTS?
Thanks,
sean
(04-12-2018, 10:56 PM)sean Wrote: Hi All,
Thanks,
sean
The PINE A64+ using DDR3 memory and PINE A64-LTS using LPDDR3 memory.
To run OpenBSD on the Pine64 LTS, use u-boot for the Pinebook (Pinebook and LTS are very similar, both use LPDDR3)...
I've got it working now!
Had to install a couple packages on my openBSD machine and copy the files to the SD card for it to boot.
(04-23-2018, 10:46 AM)sean Wrote: I've got it working now!
I have the exact same problem. May I know how you fixed it?
Brick Pine 64 Mount hole Dimensions Piney64 0 2,292 02-18-2026, 11:27 AM
Last Post: Piney64
  Pine A64 LTS V1.2 LCD DSI Boot Issue emud 1 6,422 08-08-2020, 11:29 AM
Last Post: emud
  Pine A64-LTS is build-in wifi and bluetooth? lun167 2 7,304 08-14-2018, 07:39 PM
Last Post: lun167
  Pine A64-LTS not booting williamcolls 1 5,075 03-29-2018, 01:09 PM
Last Post: dkryder
  When will Remix OS be ready for Pine A64-LTS purplecow 1 5,197 01-18-2018, 12:37 AM
Last Post: Luke
  PINE A64(+) and SOPINE related topic pineadmin 0 13,518 03-22-2017, 10:28 AM
Last Post: pineadmin
