Problem Installing Linux on Rock64
Nope, RAM size has nothing to do with it. Do you have an A-to-A cable and UART ?
For starters, if you have an A-to-A cable could you follow the instructions here and later pastebin what rkflashtool n gives you with eMMC mounted on the board?
(01-19-2018, 08:02 AM)Luke Wrote: Nope, RAM size has nothing to do with it. Do you have an A-to-A cable and UART ?
Sorry I dont know what an A to A cable is, nor a UART. So I guess the answer is no.
I just tried flashing and booting with image jessie-minimal-rock64-0.5.15-136-arm64.img.xz
This just gives i/o buffer error mmcblkp1.
A-to-A USB cable
Just tried installing the armbian image:
Armbian_5.34.171121_Rock64_Ubuntu_xenial_default_4.4.77.img
but also same result.
The bios messages about self tests USB connected etc follow ok.
I can plug and unplug mouse and keyboard and the messages on the screen register this ok.
then comes stuff like
mail device driver loaded
ALSA device list
then a list of one lines starting with 'random'
random udevadm uninitialized urandom read
final line is:
random nonblocking pool is initialized
nothing more.
EDIT: Im saying 'bios messages' but maybe they are from the OS image. Some of them reference folders  like /devices and /drivers and BTRFS. The last message line comes about 5 seconds into the boot.
if I was you I would test out the following:
* Try a different power supply, especially if the one you are using is below a 3A rating.
* See if you can get a slower SD card to try. It seems to me that (at least with mainline) the Rock64 may have some trouble with some cards. Like I have some Samsung EVO cards that seem to have problems with the Rock64 but slower Patriot Class 10 ones work OK.
(01-21-2018, 12:05 AM)wilsonYan Wrote: if I was you I would test out the following:
Well I'm using the official power supply adapter which was supplied with the Rock64 so that shouldn't be an issue.
Ive tried three different cards so far. I dont have a slower card than class 10, but the cards I have are all 2-3 years old, one of them brand new.
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,184 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 94,171 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 20,656 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,861 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,130 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,143 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,796 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,981 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 30,470 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,862 09-20-2024, 11:18 AM
Last Post: AwU2HBg
