Linux Images (ROCK64)
#51
Added Artful Minimal Community Build Image [microSD Boot] by ayufan
Updated Xenial Mate Community Build Image [microSD to eMMC] [0.5.15-136]
Updated all Linux Community Build Image [microSD Boot] [0.5.15-136] by ayufan on PINE64 Installer
Just installed this 0.5.15-136 on a 4GB rock64. tasksel seems to be neutered. Is there something that has to be installed to get it going?
There is probably just like in the Ubuntu software center an architecture check, and Ubuntu doesn't provide much/any software selections for arm64 at the moment... iirc most of the things in tasksel are also just available as meta-packages to install anyways...
But this is supposed to be a debian jessie based image, ubuntu should not enter into it.
In any event, I need to install either LXDE or Xfce for a usable X11 gui. So how do I proceed?
Thanks a bunch.
Cheers, gene83
Point about an x install may be moot, I left it running, but when It was time for amanda to back it up, it had crashed, and it is nor responding to an ssh -Y rock64@rock64 query now at 5:30 am local.  So this one isn't quite ready for prime time. I had such high hopes too.
Cheers gene83
(01-14-2018, 04:33 AM)gene83 Wrote: Point about an x install may be moot, I left it running, but when It was time for amanda to back it up, it had crashed, and it is nor responding to an ssh -Y rock64@rock64 query now at 5:30 am local.  So this one isn't quite ready for prime time. I had such high hopes too.
Cheers gene83
Yes, desktop isn't ready for prime time.
Newbie question. I've been looking at the 06.15 build images and may give this a spin when my rock64 arrives. I noticed they are minimal images. Does this include any kind of GUI? I'd like to be able to use vncserver to access the GUI from my desktop PC. What is the difference between minimal and non minimal? Planning on the Xenial image (Ubuntu).
Other thing i read in the forums is that there aren't many arm64 apps in the Ubuntu repository. If I install an arm64 image (which makes sense to me so I can use the full performance of an arm64 chip) would I still be able to use and download 32 armhf versions?
Thanks.
I am atm, running auyfan's stretch release. Not without problems mind you, but its fairly stable anyway.
Cheers, Gene83
(01-17-2018, 06:30 PM)gene83 Wrote: I am atm, running auyfan's stretch release. Not without problems mind you, but its fairly stable anyway.
Cheers, Gene83
Can you put details of the problems you are having, including build number.
130, and thew screen locker locks forever , only usable for a few minutes after a reset button reboot, I have finally gotten the locking stopped, but now the screensaver doesn't work either.
I bought these two rock64's intending to replace a pi that throws away keyboard and mouse events, while running this kernel, 4.4.4-rt9-v7+ #7 SMP PREEMPT RT Mon Mar 7 14:53:11 UTC 2016 armv7l GNU/Linux
but otherwise is running a raspbian jessie quite well. Unfortunately those missed keyboard/mouse events can leave a 1500 lb machine moving something rapidly, until it runs into the end of the mechanics. Or worse yet, runs a cutting tool into a chuck that might be spinning 900 rpm. Thats 40 lbs of spinning steel and it will be damaged at a minimum, which might be a $1000 repair.
So I need two things, the first of which I have, but haven't built and installed, which is the latest rt-kernel. Then I need to find out if the SPI is fast enough using the kernels driver. We have a user-space SPI driver for the pi's that writes 32 bit packets at 42 megabaud, and then reads the 32 bit responses at 25 megabaud. Repeat 1000 times a second. Much slower than that and the position commands, buy the time they are echo'd back to the control program, are too stale and the control program thinks there is a following error in the hardware.
So theres two problems I need to fix before I can run metal carving machinery with it. The kernels spi driver has been said to do about 10 megabaud, and that just won't cut it. But I have to try.
Cheers, gene83
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,960 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,386 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,174 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,214 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,811 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,840 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,109 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,310 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,183 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,476 09-01-2024, 06:05 AM
Last Post: RaymondDay
