Rock64 0.6.x ayufan images
Hi all.
I have a Rock64 board with 1GB, no EMMC module.
I was able to try the 0.5.10 images, like "xenial-mate" and "stretch-minimal" (with the XFCE4 desktop environment installed later), but if I try the 0.6.x images, when I power the board, all 3 leds light up and remains on, nothing else happens.
I tried both Etcher and dd command method to write the SD card (Samsung EVO 16GB).
I can exclude problems with power supply (I bought the one they suggested on their site, 5V 3A) and with SD card because I have no problem with 0.5.10 images.
Is something missing?
Thanks in advance
Matteo
https://github.com/ayufan-rock64/linux-build/releases
Notes
"Make SPL/TPL actually to work"
So try that.
(11-29-2017, 05:15 AM)elatllat Wrote: 0.6.1
Notes
So try that.
How can I do this? I suppose the image is ready to flash. I tried to search on google, but I didn't find anything useful for the image writing.
Can you help me?
Thanks in advance
Matteo
Got the same Probleme... Angry
Probably there are different productions, and some of us have different board from other. I'm not even able to use the "armbian" distribution (downloaded here: https://www.armbian.com/rock64/)
while other users can use it without problem.
Are there different productions? Is there a check about the "production"?
Matteo
is there an easy way to to update from 0.5.1xx to 0.6.1xx ?
Have you already tried ... ?
sudo apt-get install linux-rock64 -y
I am not sure if it updates from one 0.X version to another however.
Reading package lists... Done
Building dependency tree
Reading state information... Done
linux-rock64 is already the newest version (0.5.15).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
So we stay on 0.5.1x Version
(12-07-2017, 08:57 AM)Rar9 Wrote: sudo apt-get install linux-rock64 -y
Ah yes. Well, you may need to ask ayufan directly about this - best chance is IRC
I go from [microSD to eMMC] [0.5.10-118] to 0.6.x version without problem.
IIRC I do :
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,982 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,455 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,274 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,228 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,851 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,857 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,119 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,327 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,186 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,583 09-01-2024, 06:05 AM
Last Post: RaymondDay
