short boot time after power-up
i use my pine a64 as a media player to stream services like netflix,...
to be able to run the netflix app, i have android 7.0 running.
after power-up, my pine takes quite a long time to get ready for operation.
is there a way to speed up the boot process?
is there a better os than android to use the pine for streaming?
is there anything else i can do to improve performance?
thanx for your help!
(10-26-2017, 02:05 AM)bongo Wrote: i use my pine a64 as a media player to stream services like netflix,...
In short, using ayufan's android 6 will solve all the problems you mentioned.
thanx for the hint!
i'll check it out...
(10-26-2017, 04:48 AM)bongo Wrote: thanx for the hint!
Do note that initial boot / first boot will take a little longer. Also android performance is very dependent on how fast your SD card is.
(10-26-2017, 03:24 AM)Luke Wrote: In short, using ayufan's android 6 will solve all the problems you mentioned.
quite strange:
i installed the version, the above link points to, but now i'm not able to install any streaming apps like netflix or so.
whatever i try to installs, google play indicates that this app is not compatible with the os version.
what's going wrong?
thanx!
quite strange:
what's going wrong?
thanx!
No clue. Did you try sideloading ?
google updated play services last week they refined a lot of the code. you should check the build you have.
(10-26-2017, 12:15 PM)Luke Wrote: No clue. Did you try sideloading ?
neither the mentioned version of android 6 nor the android 7.1 image i downloaded allowed to install netflix (and some other streaming apps) from google play.
so i sideloaded the netflix app to test.
then i was able to enter my netflix login data, but the pine a64 then was not able to connect to netflix... i.e. it indicated that it is connecting...forever.
  Pine a64+ power supply davidspencer 0 2,332 03-18-2026, 01:02 AM
Last Post: davidspencer
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 6,876 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine A64 does only boot with Android 5.1 Dude 6 11,130 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,304 02-23-2021, 05:33 PM
Last Post: thedu
  Pine64+ power button PaddyChan 0 5,627 09-14-2020, 09:55 AM
Last Post: PaddyChan
Exclamation Can't boot when SD card inserted kivox 5 13,356 03-15-2020, 06:00 AM
Last Post: kivox
  Boot from HDD via usb BnEc 1 6,027 11-29-2019, 04:39 AM
Last Post: evilbunny
  UK power supply (Pinebook Pro 64) skobi 0 3,913 11-17-2019, 04:55 AM
Last Post: skobi
  Pine A64 stuck in boot process joey 1 5,763 05-28-2019, 09:07 PM
Last Post: joey
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 10,192 02-22-2019, 03:25 AM
Last Post: GaryFunk
