Armbian - Xenial Desktop (Pinebook)
#21
(10-19-2017, 01:03 AM)igorp Wrote: Armbian images for Pinebook has been updated. Many tiny bugs were fixed ...
https://www.armbian.com/pinebook-a64/
https://docs.armbian.com/Release_Changelog/
from this I cannot really tell which bugs were fixed/what was updated for the pinebook..
#22
thanks for the info.
will this require a reinstall (i wouldn't like that) or is a normal apt-based upgrade sufficient, or are some additional steps necessary?
anybody please?
if i'm missing something obvious, just point me to the right resources.
#23
anybody please?
Sorry, documentation is in the works - expected to be done in 2 weeks. Pinebook specifics changes are hard to define since this is in fact first nonbeta/official release. Latest beta version and this = no change. Pretty much everything works and can be used for daily work, (only urgent and not daily as on nightly builds) bugfixes can be applied remotely via apt update and upgrade, ... We are working further on kernel 4.13 but that is not ready for anything. Little more info can be scrapped here: https://forum.armbian.com/index.php?/top...ew/&page=5 If something does not work properly, we will try to fix.
#24
Armbian - Xenial Desktop (Pinebook SDCard) 5.34
- THIS IS FOR SDCard BOOT!!!
- MD5 (XZ file): e5206198a58e0399af84f56ab39d9979
- For release notes, please visit Armbian Website.
#25
(10-24-2017, 03:10 AM)pineadmin Wrote: Armbian - Xenial Desktop (Pinebook SDCard) 5.34
Trying this version on another sdcard, and again quite happy using this 5.34 version with 3.10.107-pine64.
I would rather though update my 5.32 on the emmc to 5.34 with that kernel version is that possible as well?
In any case, thank you for Armbian on the pinebook, I am a happy user! Smile
#26
(10-22-2017, 02:42 AM)igorp Wrote:
(10-21-2017, 02:20 AM)dahni Wrote: thanks for the info.
thanks. i'm not sure i understand - are you saying all your work of the last months, leading to the stable release (i installed armbian in september) can be updated via package management?
no need to reinstall or run some shell script or something, i'm not missing any important improvements?
and the things discussed in the thread are solely for developers / beta testers?
yes, i'd love some documentation on this if possible!
#27
Yes. We use Debian standard packaging system and you get updates via apt update & upgrade. We pack u-boot, kernel and board support package. Most of the things are there so it's usually no need to go from the new image. Some minor cosmetic fixes like the desktop theme, login screen or similar are not yet packed ...
Logbook is getting some data: https://www.armbian.com/logbook
#28
What is better, this one or ayuban ubuntu mate builds?
Some months off, so I read now ayufan builds has Mali and DRM support, does armbian got these also? Ty!
#29
(11-11-2017, 06:37 AM)Ekkaia Wrote: What is better, this one or ayuban ubuntu mate builds?
Its a question of taste. As for drm isn't enabled by default on either image. Read ayufan's git for instructions.
#30
Updated Armbian (Pinebook) 5.35 on PINE64 Installer. Please visit the Wiki.
  DietPi OS for Pinebook MichaIng 5 17,164 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,613 05-18-2026, 02:11 PM
  Armbian broken sometime in the last few months acruhl 4 6,441 05-29-2024, 10:44 PM
Last Post: acruhl
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 104,404 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,935 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,485 07-10-2023, 07:44 AM
  Change console resolution (Armbian/bookworm) jcgraybill 1 7,393 06-22-2023, 01:31 PM
Last Post: jcgraybill
  Pinebook no longer boots rjtanner 12 16,756 04-13-2023, 01:09 PM
  Armbian 22.02 Release Announcement TRS-80 0 4,772 02-28-2022, 05:02 PM
Last Post: TRS-80
  Stock Debian on original Pinebook moonwalkers 1 8,436 01-29-2022, 10:37 PM
Last Post: cel
