Dual boot microsd/eMMc?
Hi all, I just received my rock64 and I want to use it mainly as a small NAS with OMV installed in the eMMc. Is it possible to have Android on the microSD and using the jumper to have both systems at the same time?
Thanks, greetings
Enviado desde mi MI 5s Plus mediante Tapatalk
(10-06-2017, 02:26 AM)chitenavi Wrote: Hi all, I just received my rock64 and I want to use it mainly as a small NAS with OMV installed in the eMMc. Is it possible to have Android on the microSD and using the jumper to have both systems at the same time?
Certainly;  that's the whole point, really.   The eMMC has boot priority ,  and if the jumper is in place the eMMC clock line is held to ground effectively disabling the eMMC -- if the SD card has a valid image it will boot from there;
Shy
(10-06-2017, 07:18 AM)MarkHaysHarris777 Wrote: Certainly;  that's the whole point, really.   The eMMC has boot priority ,  and if the jumper is in place the eMMC clock line is held to ground effectively disabling the eMMC -- if the SD card has a valid image it will boot from there;
Shy
That's what I suspected, thank you [emoji16]
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,685 09-25-2026, 11:19 PM
Last Post: mysy
  Disable MicroSD reader for extra GPIO mxruben 0 12,777 07-27-2024, 10:08 PM
Last Post: mxruben
  Rock64 won't boot luminosity7 10 19,762 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 5,138 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 6,280 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,832 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,827 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 7,222 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,468 08-19-2021, 06:46 PM
Last Post: bcnaz
  boot hdd usb3 philipe 1 5,192 01-27-2021, 02:12 PM
