Feature u Think we need to improve?
Audio
51.16%
22
Rear Video
13.95%
6
GPS
34.88%
15
43 vote(s)
Pine64 Head Unit
Linux instead of android?
It can be but there are no apps that are driving friendly but if exist would be nice
Sent from my HUAWEI Y530 using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
(02-18-2016, 08:25 PM)TonyH Wrote: Linux instead of android?
The main problem with linux that there is no good navigation software for linux. I've tried Navit, but.... actually it's not as good as for example Waze.
Also in linux you'll have to use some kind of shell with icons, widgets, etc. But in Android it's already there Smile
Good news the pine64 hi-fi audio board it's on the go!
Check the external DAC thread for more details (link in the first post.)
This means that we have one thing less to care about [SMILING FACE WITH OPEN MOUTH]
By. Zoidiano0!
Installed:
Netbeans 8.1
What I would like is to use ignition as power on/off. In most cars behind the head unit there is a battery constant (yellow) and an ignition wire (red). Want to prevent the pine64 to drain the car battery when the ignition is not on (and don't want to be forced to use an external physical button).
So ideally I would wire up the pine64 directly with the car battery (yellow) (with a 12v to 5v converter) so it wont just shut down when you turn off ignition and internal clock wont reset. Then somehow use the ignition wire (red) to power on/off the device, anyone have suggestions on how to do this?
ya my plan its quite the same but i'm going to use a USB charger to power the board and filter it with some caps! so i avoid noise Big Grin
to turn on/off the Display i'm going to use a service app that monitors the Accessory cable via a relay triggered to ground using one GPIO so
if is Undefined-state - OFF
if is LOW-State-On
and i'm going to use my nexus 7 battery to power the pine while is not powered by the car Smile
in this way i avoid the battery drain Big Grin
this is something what you had on mind.?
By. Zoidiano0!
Installed:
Netbeans 8.1
a USB charger is a 12V to 5V converter, isn't it?
Using it's own battery was an alternative I was thinking of. Then you can monitor charging state instead, wake up when charging starts, go to sleep mode when charging stops. But how long would, lets say nexus 7's 4,325 mAh battery last in sleep mode for the pine64? What happens if you leave the car for a week and it dies, how can you then turn on the pine64 with the ignition?
Ya u can turn it on with the ignition
In my case i will start it with the accessory automatically cuz it's like connect the usb cable to power it up
And if u leave your car for a week and the battery(of the pine64) dies
This will charge it as soon as u switch the accessory
Its going to take a while but eventually will charge
By. Zoidiano0!
Installed:
Netbeans 8.1
#19
So how will the power up and down really work? You mentioned relays with the GOIO pins for turning the screen on and off, would it also work to power it on when battery is dead and device is off?... Would it be possible to instead edit software to check for charging state, in kernel, bootloader or some other software somehow and power up the device when charging starts.
It's been done with the nexus 7 this way; http://forum.xda-developers.com/showpost...stcount=69
Wonder if it could be done with the pine64's bootloader or kernel.
#20
Ya it can be done by software too but we need to add it to the kernel that feature (no a big deal I expect)
But I was giving you an idea of a way that it can be done
By monitoring the accessory
Or by software by monitoring charging state
When I receive my playbox I'll keep working on that kernel Implementation
And the the hole project
Do you have any ideas or suggestions for features for this project?
Please post them.
By. Zoidiano0!
Installed:
Netbeans 8.1
  Pine64 as squeezebox touch replacement Learnincurve 12 41,764 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 14,227 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 6,484 08-06-2020, 12:05 AM
Last Post: tuaris
  PINE64 to allow use of SATA disk on network/FTP mwelbourne 10 25,878 11-18-2019, 04:09 PM
Last Post: evilbunny
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 61,430 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 5,904 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 61,821 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 14,770 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 10,871 02-01-2018, 07:49 AM
Last Post: davidbrucs
Photo Nextcloud running on Pine64 gbjensen 1 9,055 01-18-2018, 05:51 AM
Last Post: Luke
