Android 7.1 (PINE A64(+))
#21
(07-27-2017, 03:21 AM)dkryder Wrote:
(07-27-2017, 01:51 AM)reeno Wrote: I've burned the image succesfully using Etcher.  However, I cant get it to boot up on pine 64 2gb.  Screen is black for a few seconds, then reverts to no signal.
I noticed that this bootlogo.bmp file is for pinebook.  Have I got the wrong image?  Image i downloaded is android-7.1-pine-a64-tv-v0.3.5-r61.img.gz
If it is the correct image, is there something I am meant to do or edit on any files before first boot?
Thanks all
it will depend somewhat on the monitor you are using and what the native resolution of that monitor or if you are using the lcd touchscreen. i've learned through experience that it is best to take a look at    uEnv.txt in the BOOT partition prior to booting. that file is pretty much a configuration file for several items including display choices.
I'm not using a touchscreen, it's plugged into TV via hdmi. Are you saying it's booting but not displaying on TV due to display config? If so what would I set it too?
#22
Thanks all
Ok I edited the UEnv.txt file and got it too boot!  However, now no sound :-(  Any ideas on how to fix.  Connecting via HDMI to tV.
#23
Just installed this image boots fine but having a couple issues.
Ethernet is not recognized and does not appear in network option. I do have wifi module and was able to connect via it.
Display resolution is to big. I am connected to a TV via HDMI cable. Ultimately would like to use this as a media box so kinda an issue.
I have 2GB board had been using it connected to touch screen for about a year now and am now dedicating it to media. This is the first time I have tried to use the Ethernet.
(08-01-2017, 05:14 AM)gubaguba Wrote: Just installed this image boots fine but having a couple issues.
Resolution is too big ?  Do you mean that its 720p and all icons seem very large, or do you mean that the picture goes beyond the edges of the screen ?
If its the prior, then read ayufan's first post on how to set resolution in uEnv. If its the latter, then its called overscan. Different TV manufacturers have different names for this -- either way, you will have to correct the image on your TV from within the TV settings menu.
#25
Yes you could describe as overscan. Will try to edit the file. Please could you provide path to the file to be edited.
#26
Solved the display problems to my satisfaction. Still no Ethernet. Is it functional on this build?
#27
(08-01-2017, 08:29 AM)gubaguba Wrote: Solved the display problems to my satisfaction. Still no Ethernet. Is it functional on this build?
Update: System will not boot with Ethernet plugged in. If I plugin after boot bluetooth stops working. Suspect it might be hardware issue. Mine was a fairly early board.
#28
Unlikely. Try ayufan's A6 release image and report back.
#29
(05-19-2017, 02:37 PM)HKha0sprinz Wrote:
(05-18-2017, 01:12 PM)Israeldelamo Wrote:
(05-18-2017, 12:56 PM)Kha0sprinz Wrote: I still don't got any sound on Android Builds :/ With Linux installed all working fine, but as soon as it comes to Android, the sound is not working. Not with HDMI and neither with the clinch... so annoying... Any Ideas?
Yes, actually I managed to get sound working quite good during one of my "case building experiments". I soldered directly a spekaer to the Pine64 but in or order to make it work it has to be detected (something related to a mini-jack connection) so I used this program
https://play.google.com/store/apps/detai...gfix&hl=es
that allows you to direct the sound anyway you want. Try it and tell us.
Did you manage to get the touchscreen working, or I am the onlyone?
Already tried that App. Still don't work :/
I don't use a Touchscreen, so I'm out there^^
Has anyone found a fix??? I'm three boards down. Should have stayed with android 4
#30
Android 7.1 (PINE A64(+)) v0.3.10-r66
Edit: This release includes Android 7.1 TV.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,753 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 612,073 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,570 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,219 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,793 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,379 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,659 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,812 07-15-2019, 08:29 PM
  Bliss OS (PINE A64(+)) pineadmin 4 18,376 06-07-2019, 09:01 PM
Last Post: nukedawg
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 411,210 03-12-2019, 04:53 PM
Last Post: neosapien
