Recovering root access in Ubuntu
Yesterday I had cause to add the ubuntu user to the www-data group. I believe I did this:
# usermod -G www-data ubuntu
Since then, I am unable to become root. If I try to sudo -i, I am told
Sorry, user ubuntu is not allowed to execute '/bin/bash' as root on pine64.
This happens no matter what command I try to run. sudo vim /etc/sudoers?
Sorry, user ubuntu is not allowed to execute '/usr/bin/vim /etc/sudoers' as root on pine64.
I don't actually know if adding ubuntu to a group caused this; it's just the biggest change I've made, and I can't think of anything else I've done that would cause this.
Thanks!
(07-26-2017, 01:05 PM)Scientomancer Wrote: Yesterday I had cause to add the ubuntu user to the www-data group. I believe I did this:
Thanks!
hi,   hmmm  not run into anyone trying to do this to themselves before;
... do you really want anyone in the www-data group to also be in the soduers file ?   ... probably not.
While I'm not precisely sure what you have done to yourself, you can undo it by placing the SD card into another linux machine and mounting the ext4 partition containing /rootfs and removing the offending change.
Unfortunately, you haven't ADDED the ubuntu user to the www-data group, you've REPLACED the ubuntu primary user group with www-data, and consequently removed it from all other groups. For future reference, the command should have been -aG (yes, the a is important!). And because the root account is locked by default, unless you unlocked that, you can't log in as root to re-add ubuntu to the sudo group.
If you have another linux systen handy (or you can download VirtualBox and run a copy of ubuntu in a virtual machine, or make a bootable USB/CD), you could mount the ext4 partition, and edit /etc/groups, and re-add your username to the end. i.e. on my desktop, the sudo group line looks like this for the 'pfeerick' user. So just look for the sudo line, don't change the group number if it is different, and re-add ubuntu to the end. Then unmount, boot it back up, and see if it's fixed Wink
sudo:x:27:pfeerick
I successfully recovered using the method suggested: mounting my system's filesystem on another machine and editing /etc/group. Thanks very much! Sorry that this didn't turn out to be a Pine specific question.
  Ubuntu server 20.04 request phi0x 2 11,439 12-30-2020, 08:02 PM
Last Post: phi0x
  SPI on ubuntu IlyaM 4 15,033 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,628 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 18,083 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 958,237 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 13,849 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 15,827 08-03-2017, 03:52 PM
Last Post: Luke
  Ubuntu boot very slow with wifi driver remainder 9 28,786 08-03-2017, 07:23 AM
Last Post: victorssantos
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 4,713 07-08-2017, 09:34 AM
Last Post: petec
  Ubuntu Xenial - Firefox add support for H264 and EAC3 klode 1 7,248 05-26-2017, 11:10 AM
Last Post: Gnx
