Debian Stretch on Pine64 (run rock64 images on pine64)
Any chance a linux image for Rock64 run on Pine64?
https://github.com/ayufan-rock64/linux-build
I wish o could run debian strech kernel 4.*.
Nope, different SOC so no chance. I believe Lenny is working on a debian strech for Pine64, but don't quote me on this - regardless that will obviously run 3.10.X
No, you can't run rock64 images on the pine64, you have a completely different SoCs here... the Rockchip RK3328 vs the Allwinner A64. This is why the rock64 is already on a 4.4x kernel, because it is getting different support.
If you really NEED a 4.x series kernel, and want to see what the stability of it is on the pine64, try one of the Armbian mainline kernel builds. But be warned, as it says on the tin, these are experimental builds, as mainline (4.x) does not fully support all the stuff that on the pine64... it's nearly there, but not quite).  However, for stability, you are much better off with the 3.10.x kernels, as they do work quite well, it's just that they're just old (is probably best to not have anything 'sensitive' on it if it is accessible over the internet, though, since it is about to go EOL, and there have to be vulnerabilities that haven't been patched in it that have been fixed in the newer 4.x series).
Great, thanks guys!
  ROK OS v7 OK Bitcoin Fullnode OpenBazaar for Pine64+ OKtoshi 9 27,942 05-21-2021, 12:14 PM
Last Post: killor
  lost eth0 on my pine64 psarazin 7 16,161 03-22-2021, 05:55 PM
Last Post: kuleszdl
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,121 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,628 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,579 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,998 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 166,723 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,462 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Installing DietPi to EMMC on Rock64 rrosenheim 0 5,363 05-29-2019, 10:13 PM
Last Post: rrosenheim
  Script to build pure Debian images for Pine64+ amp 1 7,820 05-01-2019, 09:09 PM
