Does the ROCK64 support CEC over HDMI?
Does the ROCK64 support CEC (Consumer Electronics Control) over HDMI?  CEC allows the SBC to turn a connected HDTV on (and off) over HDMI, change the HDTV's input, and possibly control other functions.
I believe the Raspberry Pi has CEC support.  While I have never used CEC on a Raspberry Pi, I do have some project ideas in mind.
More info here:
http://elinux.org/CEC_(Consumer_Electron..._over_HDMI
Thanks!
Yes. It already does work on Android, but controls to support that on Linux are also present: https://github.com/rockchip-linux/kernel...able&type=. We may need to upgrade libcec to support a new device, but I wonder if exynos compatibility layer would not work OoB.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
(07-05-2017, 02:53 PM)ayufan Wrote: Yes. It already does work on Android, but controls to support that on Linux are also present: https://github.com/rockchip-linux/kernel...able&type=. We may need to upgrade libcec to support a new device, but I wonder if exynos compatibility layer would not work OoB.
I can find the cec function in the hdmi settings. but unfortunately they turn off automatically after turning on. I used the cec function under LibreElec Leia of Raybuntu but this operating system is absolutely unstable and does not work as required. for my purposes, only the android of ayufan currently works properly. Thanks a lot for this. the more I would be glad if the cec problem and one or the other bugs could be solved. I also regularly experience a loss of network connection via the RJ45 socket. if I unplug the cable and insert again the connection is immediately available again but unfortunately not constant. I use the regular android 7.1.2 root version.
thanks again for your great work and keep it up. I will test your pre-releases today.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,972 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,439 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,227 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,219 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,842 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,849 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,112 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,319 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,183 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,552 09-01-2024, 06:05 AM
Last Post: RaymondDay
