Flashing New OS Images to eMMC / Booting from SD
Exclamation
In order to flash a new image for the Pinebook to either eMMC or microSD please use the installer utility provided by Pine. The Installer utility supports all major platforms - Mac OSX; Linux; Windows 7/8.1/10, but CANNOT be run on the Pinebook itself if you wish to use it to prepare another SD card - you will need a standard x86/64bit machine to run this tool.
Here  are the step-by-step instructions for flashing an image for your Pinebook:
  1. Launch the installer and click Choose an OS
  2. From the drop-down menu select Pinebook (see attached screenshot)
  3. Choose the OS you wish to install (take note of the information in brackets - Pinebook eMMC / Pinebook SDCard - it determines what your chosen OS will boot from) and click OK
  4. Instert a MicroSD card to your computer and press Flash! The chosen OS will be downloaded, flashed and verified by the utility.
  5. After the process completed, remove your SD card and intert it into your Pinebook's MicroSD slot.
  6. If you chose a Pinebook eMMC Image, follow the onscreen instructions to flash your selection internal storage. If you opted for an image that boots from MicroSD, then your Pinebook should boot with the new OS straight away.
If you wish to discuss flashing images and upgrading eMMC memory then please post in this thread under Hardware and Accessories.
[Image: MEPZ1vn.png]
  Not booting anymore from SD oloturia 0 12,740 09-29-2023, 10:18 AM
Last Post: oloturia
  Booting with TOC0 u-boot -- should it work? dreadbit 0 3,637 11-24-2022, 10:19 AM
Last Post: dreadbit
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 5,429 03-08-2022, 10:14 AM
Last Post: frank-zappa
  How to transfer customised OS from SDcard to emmc quixote 1 9,210 01-07-2022, 06:38 AM
Last Post: alanwake82
  [major issue] how to stop it from booting when charging? eFqLLnGo 2 7,996 07-03-2021, 09:22 PM
Last Post: jezek
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 18,715 12-07-2020, 04:02 PM
Last Post: SanjevR
Bug No Images work except one. psiie 3 9,194 05-15-2020, 02:09 AM
Last Post: pfeerick
  eMMC backup milkaca 19 43,740 04-08-2020, 07:35 PM
Last Post: adamz
  Any FYDE OS (Chromium with Android) images? mitcoes 1 5,825 12-02-2019, 12:18 PM
  Pinebook Pro availability, booting from NVMe nooryani84 8 19,551 09-16-2019, 11:07 AM
