Android 7.1 Tablet and TV (alpha, proposal)
#21
@ayufan:
A small patch to fix compilation error on 7.1
diff --git a/services/tests/servicestests/src/com/android/server/ConnectivityServiceTest.java b/services/tests/servicestests/src/com/android/server/ConnectivityServiceTest.java index 012bdd8..65f9399 100644 --- a/services/tests/servicestests/src/com/android/server/ConnectivityServiceTest.java +++ b/services/tests/servicestests/src/com/android/server/ConnectivityServiceTest.java @@ -620,19 +620,6 @@ public class ConnectivityServiceTest extends AndroidTestCase {         }     } -    private class WrappedAvoidBadWifiTracker extends AvoidBadWifiTracker { -        public boolean configRestrictsAvoidBadWifi; - -        public WrappedAvoidBadWifiTracker(Context c, Handler h, Runnable r) { -            super(c, h, r); -        } - -        @Override -        public boolean configRestrictsAvoidBadWifi() { -            return configRestrictsAvoidBadWifi; -        } -    } -     private class WrappedConnectivityService extends ConnectivityService {         public WrappedAvoidBadWifiTracker wrappedAvoidBadWifiTracker;         private WrappedNetworkMonitor mLastCreatedNetworkMonitor;
#22
I don't have compilation problems Smile
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
#23
I've installed yesterday 0.3.6 on my pine64. Everything is working well on HDMI screen, but on LCD screen (pine64 official LCD 7" screen), touch pannel is not working (display ok). Is there something to activate ?
Thank you !
Math
#24
Not sure, it should work. On the spare moment I will test that.
Releases:
Buy me a Beer
#25
(05-31-2017, 09:16 AM)ayufan Wrote: I don't have compilation problems Smile
mh strange, WrappedAvoidBadWifiTracker is declared twice, https://github.com/ayufan-pine64/framewo...#L610#L634
btw, could be this useful in any way for pine users? https://developer.arm.com/products/softw...li-drivers
keep up the good work Wink
#26
Something terrible just happened, my kids broked USB IR receiver on Pine.
Is it possible to use Pine built-in IR receiver on Android?
I found this guide for OPi, but can't find module sunxi_ir_rx in Pine Android build:
http://www.orangepi.org/orangepibbsen/fo...ad&tid=541
#27
How to use UART4? I connected the GPS module through Euler connector to UART4.
pin  9 GND --------------> GPS GND
pin 17 3.3v --------------> GPS 3.3v
pin 19 PD2 UART4_TX -> GPS uartRX
pin 21 PD3 UART4_RX -> GPS uartTX
|tulip-chiphd:/ # cat /dev/ttyGS3
there are no data
tulip-chiphd:/ # ls -l /dev |grep tty
crw------- 1 root      root         252,   0 2017-02-05 20:50 ttyGS0
crw------- 1 root      root         252,   1 2017-02-05 20:50 ttyGS1
crw------- 1 root      root         252,   2 2017-02-05 20:50 ttyGS2
crw-rw-rw- 1 root      root         252,   3 2017-02-05 20:50 ttyGS3
crw------- 1 root      root         253,   0 2017-02-05 20:50 ttyS0
crw-rw---- 1 bluetooth net_bt_stack 253,   1 2017-02-05 20:52 ttyS1
In linux  ARMBIAN 5.25 it`s working
root@pine64:~#  cat /dev/ttyS4
$GPRMC,073356.000,V,0000.000,N,00000.000,E,0.0,0.0,060617,0.0,W*6F
$GPGGA,073356.000,0000.00000,N,00000.00000,E,0,01,99.0,082.00,M,18.0,M,,*5B
#28
(06-01-2017, 02:31 AM)ayufan Wrote: Not sure, it should work. On the spare moment I will test that.
Hello, Have you got time to test ?
#29
(06-01-2017, 02:29 AM)Math43 Wrote: Hello,
I hate to ask a dumb question, but did you plug in the tp ribbon cable ?
... the tp cable is taped to the display and often not noticed by people.  If you forget to plug it in, the touch will no worky.
Rolleyes
#30
Rolleyes
Hello, there is no dumb questions Wink
Two cables are plugged, i've a sd card with android 6.0 and another with 7.1, only thing i've change is switching sd card, touchscreen is working under android 6.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,763 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 612,677 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,582 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,232 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,800 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,391 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,669 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,820 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 411,256 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,603 02-26-2019, 11:58 AM
Last Post: Twistedx
