Which OS will you be running on the Pinebook?
Linux
94.83%
55
Android
5.17%
3
58 vote(s)
BSP Linux woes, early adopter information and a poll
#21
I've written a script to apply the patched ALSA config file which enables the speaker output. You can either download the script and run it on a machine offline (remembering to make the script executable in order to run it), or if you have internet access on your machine, download and run it directly:
sudo -i bash <(curl -s https://raw.githubusercontent.com/pfeerick/pine64-scripts/master/pinebook/no-speaker-fix.sh)
#22
(04-28-2017, 02:56 AM)pfeerick Wrote: I've written a script to apply the patched ALSA config file which enables the speaker output. You can either download the script and run it on a machine offline (remembering to make the script executable in order to run it), or if you have internet access on your machine, download and run it directly:
Thanks! that said, sound has been fixed in the newest image.
#23
(04-28-2017, 03:15 AM)Luke Wrote: Thanks! that said, sound has been fixed in the newest image.
But that isn't out yet, is it... so or was this (and other fixes) in the image released on the 25th? A changelog is really needed for the images in order to work why download a new one.
#24
worked for me with the latest image from the Pine Installer dated 25/04
Edit: ok, sounds gets reset after reboot even on the new image....
#25
We found out it get reset if you performed suspend.
#26
lukasz: nothing has to be specially enabled, as it works out of box.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
#27
(04-30-2017, 08:17 PM)ayufan Wrote: lukasz: nothing has to be specially enabled, as it works out of box.
I guess you mean hall ? ok, fixed post Smile
#28
The most recent kernel patch brings the hz refresh rate from 56hz to 63hz.
While it doesn't have a 'real' impact on the PBs performance, it sure does 'feel' smoother.
You can upgrade your current image using the available scripts like so
sudo ./pine64_update_kernel.sh 0.5.5 sudo ./pine64_update_uboot.sh 0.5.5 sudo ./pine64_update_package.sh 0.5.5
#29
(06-06-2017, 07:18 AM)Luke Wrote: The most recent kernel patch brings the hz refresh rate from 56hz to 63hz.
I felt some flickering in PB11 and returned to 0.5.4
#30
flickering ? I haven't experienced anything of the sort and I have been trying it out for the past few hours. Perhaps I missed something ? When does the screen flicker - generally when working in the desktop, when opening an application, when watching a movie in SMPlayer/ VLC, etc ? (I tried all the above, no flickering on my end).
  Information about new Pinebooks junker 1 7,337 09-16-2020, 10:29 PM
  eMMC boot linux distros for Pinebook. frank-zappa 14 33,657 09-06-2019, 08:39 AM
Last Post: frank-zappa
  I need some summary information about hardware support by OS for a newbie tahf 10 23,619 01-25-2019, 10:01 AM
Last Post: tahf
  Poll: Which distro do you use for pinebook? erchache2000 2 7,695 09-12-2018, 12:36 AM
Last Post: Wizzard
Information Flood of basic linux questions skot 4 9,935 08-12-2017, 03:52 PM
Last Post: MarkHaysHarris777
Information Linux image with DRM + Mali Luke 1 10,438 08-05-2017, 10:49 PM
Last Post: abrmx
  ayufan's Linux and Android builds Luke 0 5,146 04-30-2017, 09:46 AM
Last Post: Luke
