RESOLVED - LCD screen not working, HDMI does
EDIT: IT WORKS! - THE ONLY THING I DID DIFFERENT WAS USE NOTEPAD++ TO UNCOMMENT THE UENV.TXT FILE RATHER THAN NORMAL NOTEPAD (SORRY IF THAT WAS AN OBVIOUS MOVE? BUT IT WASN'T TO ME. Thanks to everyone for the help though
Hey
I know there are other threads out there with similar issues and people have managed to fix it, but i have tried everything that i'm aware of and can find but i cant get my LCD to work.
(I have the 2gb Pine)
  • All cables are correctly connected
  • I've disconnected the keyboard USB and camera
  • It's definitely the right image (android LCD - i have used the android 6 LCD and the android 7 DD image (64gb) ) (I used 7zip and rufus for the image writing)
  • The power light stays on when plugged into HDMI but doesn't always when plugged into the LCD (its really temperamental - sometimes it stays on sometimes it doesn't it depends what image I'm using  - v6 it stays on - v7 it didnt stay on at first now it does - but on both images the screen is blank.
  • I have plugged it into my tv using the HDMI cable and it works fine.
EDIT - I'm using the official Pine64 power supply, 64gb card sent from Pine64 -
EDIT - I managed to get the LCD to work with the earlier android 5.1.1 version (8gb image) but it crashed very quickly
EDIT - tested SDcard with Htestw and it's fine
With both images when plugged into the LCD and the power nothing happens at all no screen flash or anything its just blank. any help would be greatly appreciated.
I'm a bit late in the game in setting up my pine!
if you need any more info please let me know
Backer number #9,952 + KS Funded Jan 23, 2016 + Backerkit funded May 9, 2016
STATUS: RECEIVED,TRACKING NUMBER = PENDING, SHIPPED 27/05/16
(03-29-2017, 06:47 AM)asuras Wrote: Hey
It's definitely the right image (android LCD - i have used the android 6 LCD and the android 7 )
The power light stays on so it's not that i don't think.
Strange, Android LCD should work without any tinkering. Make sure you are using one of the images denoted as: If you are using ayufan's build then you'll need to edit uEnv.txt to include the following:
pine64_lcd=on
(03-29-2017, 06:58 AM)Luke Wrote: Strange, Android LCD should work without any tinkering. Make sure you are using one of the images denoted as: If you are using ayufan's build then you'll need to edit uEnv.txt to include the following:
pine64_lcd=on
Yeah that's the image i tried first and it didn't work
Just tried adding that code now the power light stays on for about a minute then goes out, it's being super tempermental sometimes the light stays on and nothing happens and sometimes it goes out after like a minute or two.
Whats your PSU rating ? A solid 5V 3A is what you should be using ... sounds like a power issue to me. You may want to ask in the android thread
(03-29-2017, 12:30 PM)Luke Wrote: Whats your PSU rating ? A solid 5V 3A is what you should be using ... sounds like a power issue to me. You may want to ask in the android thread
Right i got it working but using the old android ver5.1.1 8 gb - so i don't know what the issue is with the other ones.. any idea? should i try using a smaller image maybe on the newer versions? (my sd card is the supplied 64gb)
EDIT - one thing i noticed is that when i used the older android version my sdcard labelled itself 'boot' and with the other ones it didn't would this cause an issue?
Has anyone else had issues with the newer android builds 6/7 and managed to fix it? ( I have edited the file that didn't seem to do much)
The power supply should be fine I'm using the one supplied by Pine64 I've tried other power supplies and they don't work, but the power works for HDMI and the earlier 5.1.1 android version.
power also stays on for v6 but the LCD screen is blank - and now its seems to stay on with v7 but the screen is also blank...
can anybody help? I've asked on the android forum to no avail Sad
I think it would be best if you chatted with ayufan directly.
Join the IRC in EU CET afternoon or evening and 'ping him' by using his nick.
Ask the question and wait - it may take some time for him to respond, so don't ask and leave after a few minutes. You have the shortcut to the web chat in my sig.
(03-31-2017, 03:33 PM)Luke Wrote: I think it would be best if you chatted with ayufan directly.
Thank you Smile
Ah just saw your comment in the top post, yes normal Notepad will screw up the Unix line endings, you need some more advanced editors under Windows that preserve Unix/Windows line endings, like Notepad++
(04-01-2017, 05:04 PM)xalius Wrote: Ah just saw your comment in the top post, yes normal Notepad will screw up the Unix line endings, you need some more advanced editors under Windows that preserve Unix/Windows line endings, like Notepad++
Indeed. In a pinch, on Windows, Wordpad is also an almost always available 'built in' option... which thankfully does preserve line endings. Notepad just mangles the lot. Notepad++ is always handy to have on hand though Wink
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 6,787 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  7" LCD Touch Screen Panel IanJames 0 3,324 04-01-2020, 04:40 PM
Last Post: IanJames
  Pine HDMI -> DVI monitor Pineapple 4 12,233 09-10-2019, 11:28 AM
Last Post: Pineapple
  User Screen Black After Changing Power Settings 0b51Gekko 2 7,672 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  Input not working after a forced shutdown dic1911 1 5,430 12-24-2018, 07:45 PM
  First Boot HDMI/USB problem reefer 1 7,083 11-18-2018, 10:32 PM
  Any success working with OpenCV on the PineA64? Tonny91 0 3,634 10-16-2018, 09:16 PM
Last Post: Tonny91
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,185 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Rock64 + 7" touch screen naviathan 2 7,246 09-28-2017, 09:01 AM
Last Post: naviathan
  7" Screen - Does it work with Debian abasel 1 5,911 07-26-2017, 05:44 AM
Last Post: pfeerick
