Acrylic enclosure for PINE A64
(02-18-2016, 09:38 AM)Informatica Wrote: Hi killor,
could you share with us the project/model used for the laser cut machine??
Hi !
The measurements place are taken from the wiki.  Pine A64 Rev B PCB dimension
all you have to add the the height for each connector,
I have taken measures height connectors that I have at home on other devices, like  router , Laptop or Raspberry Pi, tv screens ,etc....
 as they are standard components ..
They fit well on the actual board..
“施主肤浅了,授人以鱼,不如授人以渔,难道这个道理你不懂吗?鱼你吃完就没了,可是你可以用鱼竿钓很多鱼,可以用一辈子!"
One of the changes I am making is on my acrylic enclosure design is:
I'm adding a Button cell 3V Battery Holder CR2032 for RTC ..
I've already ordered the Mini Micro JST 2.0 PH 2-Pin Connector Plug with Cables Wires..
The lipo battery  one option is 1200mAh 3.7V Li-Poly Battery with JST-PH cable
but I have to investigate further.
Where available, I will include in orders for this design.
You casing looks great.  I would love to get one of these from you if possible. I live in the US.
(02-23-2016, 06:22 PM)lenwe33 Wrote: You casing looks great.  I would love to get one of these from you if possible. I live in the US.
Hello lenwe33
If soon be available on Amazon USA warehouse ,
I'm waiting for the Micro JST 2.0 PH 2-Pin Connector plug to include in the RTC battery holder kit
Right now we have ready at Amazon USA warehouse,  a wooden version (without RTC kit)
Thanks for your interest..
Wondering if the acrylic will be available thru amazon? It looks cool
(02-25-2016, 11:00 PM)brjaan Wrote: Wondering if the acrylic will be available thru amazon? It looks cool
Yes,  when receiving the Micro JST 2.0 PH 2-Pin Connector , I will begin to send Amazon...
Por favor, ponla en Amazon con envío en un día a ser posible, sin mínimo de compra. Tengo premium y sería un puntazo si se puede mantener el precio, así muchos no tendríamos que pagar un extra por el envío por agencia.
(02-26-2016, 08:21 AM)RaspiBit Wrote: Por favor, ponla en Amazon con envío en un día a ser posible, sin mínimo de compra. Tengo premium y sería un puntazo si se puede mantener el precio, así muchos no tendríamos que pagar un extra por el envío por agencia.
Ahora en Amazon España hay solo cajas de madera, (bueno realmente estan en Alemania , Francia e Reino unido )
pronto cuando reciba los conectores PH2 para terminar el porta pilas de boton del reloj RTC , entonces enviare las cajas acrilicas para AMAZON.
No te preocupes ya te mandaré un mensaje cuando las tenga listas...
¿El diseño tiene en cuenta el espacio necesario para pulsar los switches de encendido y reset?
(02-26-2016, 09:36 AM)RaspiBit Wrote: ¿El diseño tiene en cuenta el espacio necesario para pulsar los switches de encendido y reset?
Le he dejado una abertura pero al no ver que tipo de switches se usaran no está totalmente exacta...
How is it going?
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 241,214 11-02-2020, 08:43 PM
Last Post: Little_Johnny
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 16,002 09-17-2020, 06:41 AM
Last Post: dabou
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,836 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,844 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,829 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 30,450 07-18-2017, 10:39 AM
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 17,152 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,591 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,985 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,988 02-12-2017, 10:17 PM
