Android 6.0 Tablet and TV (release candidate, maintained)
(02-05-2017, 07:44 AM)Jux89 Wrote: Hello,
I try to run android-6.0-pine-a64-tv-v1.1.3-r26.img, at first boot I only see a screen filled with red color. Wait more than 20 min and noting is changing..
I Burned the img with Etcher and also with Win32diskimager, Both did not work. I got an Samsung EVO Pro SD card 16gig.
Android 5 was running fine on my Pine64 A+2gb..
Hope you guys can help me,
edit: I tried android-6.0-pine-a64-tv-v1.0.1-r20.img and its booting now, guess the pre-releases are not working yet?
How did you burn the 101r20 image?  Im still getting the same salmon/red colored screen.
Using the software from : https://etcher.io/ , I did not change any of the uEnv.txt settings..
Keep in mind i'm using TV version.
Goodluck!
Hi guys I'm new to this forum and pine64 word.
I downloaded and flashed a Remix OS Image. it work fine on a TV with 1080p support, but is not working with a TV with 1080i support.
I read about editing uEnv.txt file, but I didn't find that file.
how can I reach that?
thx
Question
(02-08-2017, 04:09 AM)spanocchio Wrote: Hi guys I'm new to this forum and pine64 word.
thx
You need to plug your SD-Card into a regular PC, and mount/open the boot partition (it is labeled "boot"). It should be right in the root of the boot partition!
Hope that helps
Quick question for you all. I just tried the latest releases but as soon as I plug the power in, I'm getting a solid orange screen and no boot. Previous versions I tried worked great (last image I used was a few months ago). I tried editing the boot file to change resolution, and tried tinkering with the "hdmi0 hdmi1" options - same result.
Tried swapping to the 2nd HDMI port on my TV - same problem. Also tried burning with DD and etcher. - same result.
Hopefully if someone has some guidance regarding this, that would be highly appreciated.
Cheers!!
I cannot write files to USB, is there any advice? Thank you...
Ayufan: Would it be possible to include the video player from RemixOS or from "official Pine" Android 6 release (I guess it is the same player)?
http://wiki.pine64.org/index.php/Main_Page#Android_6.0
http://wiki.pine64.org/index.php/Main_Page#Remix_OS_2.0
This video player works really nice esp. for HEVC. I have tried to use app extractor, but video player is always crashing in your latest release.
Possible to include in the settings the screen scraper? On the curated images they have the option for under/overscan adjustment.
How do i disable HDMI CEC by modifying uEnv.txt?
I have tried many ways, but the Pine still keeps my receiver awake when i'm turing off the tv.
It works perfectly when the Pine is not connected.
1.1.3 does not load on my Pine (1gb) either (no respons to my TV, not even blank screen). In the log it says Pinebook. Is this one only for Pinebook and therefore no boot on normal PINE?
PineBook is a different device and is pre-release scroll down and download latest release 1.0.2.
https://github.com/ayufan-pine64/android-6.0/releases
Wished ayufan could separate the pinebook into a different folder.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,695 08-20-2026, 08:45 AM
Last Post: ahegarosib97
Shocked Remote for Android? liodra 18 50,386 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,133 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,746 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,334 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,621 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,785 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 410,618 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,561 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 162,876 02-10-2019, 07:44 PM
Last Post: mmmarcus
