Lithium 3.7 Volt Battery
#41
(09-20-2016, 02:39 AM)pfeerick Wrote:
(09-19-2016, 01:17 AM)Israeldelamo Wrote: Would you kindly post a picture of that connection, or at least a diagram? The last time i tried to connect a 3,7v battery I fried my Pine64 (30€ thrown away). Angry
Sorry for the delay... have been fighting with bluetooth all afternoon! Wink
I'm presuming this is the sort of pic you wanted? If you look at the markings on the board, they match the order of the wires... + (positive) is the red one on the left, and - (negative) is the one on the right. The middle one (yellow) is the thermistor, or a 10k resistor connected to GND if you have a battery without a thermistor.
If you wish to use the connections on the euler bus (as they are a more practical 2.54mm header connector), you can connect to these pins. Just be warned, just like with the battery conector, you can't put this backwards without releasing the magic blue smoke! Sad
Thanks, I will try again to see if this time i dont fry the board. By the way, what about using a couple of 18650 li-ion battery cells. Would it work? with four of those we would have a very nice battery time wouldn´t we?
(09-28-2016, 10:23 AM)Israeldelamo Wrote: ... what about using a couple of 18650 li-ion battery cells. Would it work? ...
As long as you use them in parallel (all positives connected together, all negatives connected together), then yes, that would work. As the batteries are never perfectly matched or balanced, I would recommend you use batteries that have protection circuits on them, or add some (they're really cheap on ebay). This will ensure that no single cell is under or over discharged. This may be being over-cautious since when the cells are paralleled up they are effectively one battery, but it just prevents any nasty things happening, and at around $1 a board, the protection circuits are worth that extra peace of mind!
Hey guys I have a bunch of 185650 and a artery pulled from my old Nexus 7 that is 4000+mah
But I'm connecting the leads of the battery to the connector and I have a termistor between the middle pin and ground but nothing happens and I measure the voltage across that circuit and its no more than 1.5v
But the battery is fully charge
Any ideas of what's going on
BTW I have tried that jumper in battery and normal mode
Sent from my Xperia V using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
Hi ,
do i Need a 10k or a 100k Thermistor for the Battery
I want clue one on the Battery and connect it to Black (-) and the Yello (middle Port)
With the wrong Thermistor the Pine get incorrect values and whould not Charge.
So Long
With the default register settings for the AXP803 the NTC should be a 10k type. The datasheet suggests Murata NCP15XH103F03R for example.
Hello I'm in France so I can't order the battery from the official store so I was wondering is this battery would be compatible ?
https://www.amazon.fr/vhbw-Li-Polymer-Ba...7V+8000mah
And would the connector be compatible withe be Pine64 :
https://www.amazon.fr/ensembles-Micro-Co...+3+femelle
(07-13-2017, 02:46 PM)Shotmann Wrote: Hello I'm in France so I can't order the battery from the official store so I was wondering is this battery would be compatible ?
The battery seems fine looks to be fine... it is the right voltage (single cell, 3.7v) and chemistry (lithium-ion polymer).
Those are the wrong connectors though... you want the the 3 pin JST-PH type connector. From that same site, these are the correct type: https://www.amazon.fr/ensembles-Micro-connecteur-Fiche-150mm/dp/B01DU9OY40/ref=sr_1_1?ie=UTF8&qid=1500006533&sr=8-1&keywords=JST+PH+3+pin
Pine64 has designed a Lithium Ion battery holder case and also design in protection circuit. Here is the PINE64 store link: https://www.pine64.org/?product=lithium-battery-casing.
You can source the 18650 Lithium Battery locally and you can install 1-3 pieces.
Can the battery holder case fit Inside the playbox enclusure ? https://www.pine64.org/?product=pine64-p...-enclosure Because I'd like to make the Pine64 fully portable
Yes, the battery holder case can fit inside the palybox enclosure.
Rainbow Lithium battery temperature readout? GregH 0 2,920 03-12-2020, 12:05 AM
Last Post: GregH
  Battery level measurement? HugoRabson 2 6,082 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 8,015 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 42,257 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 5,665 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 80,298 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 14,245 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 3,523 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 3,437 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 26,727 02-18-2016, 05:17 AM
Last Post: German
