Lithium 'salt and battery
I ordered three of these from e-bay :
    http://www.ebay.com.au/itm/111706418228
I've only got 2 Pine 64 (2GB), but I can always use another one with NextThing CHIP.
I also ordered 4 of these (thinking it was 1 per package - but turns out I'm getting 40 of them!) :
    http://www.ebay.ca/itm/201477249384
I can always rig them up as adapters to convert between 2 pin and 3 pin connectors...
Rainbow Lithium battery temperature readout? GregH 0 3,201 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 107,127 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 6,708 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 9,046 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 46,638 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 6,151 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 86,869 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 15,559 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 3,814 06-20-2016, 07:38 PM
Last Post: xalius
  Minor note about the RTC battery MichaelMeissner 12 29,091 02-18-2016, 05:17 AM
Last Post: German
