power supply
Sad
I saw your web page FAQ is use USB 5V 2A , but kickstarter update #20 reply message  USB 5V 2.1A , who is true ?
because i use USB 5V 2A
thank
(01-20-2016, 04:31 AM)Wing Wrote: Hello,
thank
5V2A should work
thank
5V2A should work
Can it accommodate a 220-240V?
thank
5V2A should work
yes
Both should work fine.
I think that you could use less than 2 Amps but you wouldn't have the full capability of the board 2.1 Amps is just the recommend power supply
I have a 5v 3.0amp micro usb unit will this be ok for P64+ 2Gb board ?
(02-17-2016, 05:18 AM)Phlebas Wrote: I have a 5v 3.0amp micro usb unit will this be ok for P64+ 2Gb board ?
Short answer: yes.
Short answer: yes.
Thank you
If the power supply always delivers 3.0 amps, no matter what you connect to it, then it would work. However, there are some micro USB power supplies that try to be 'smart' and will only deliver higher amps if they are connected to a phone that they recognize. If they connect to an unknown device, they might throttle the power down to 0.5 amps (500mA).
The other issue is whether the power supply is designed to deliver 3 amps all of the time without overheating, or it is meant to deliver 3 amps as a peak amount. It really depends on how well it is made.
Haha, yes. That is the longer answer Smile
  New RockPro64 Power Up Problem enorbet2 7 13,094 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 3,320 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,432 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,287 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 23,613 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 8,174 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 7,769 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 11,526 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 3,932 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 9,414 10-23-2016, 12:16 PM
Last Post: dkryder
