Wifi module able to share ethernet connection? Connection is unstable!
I noticed that when pine64 and the client device are too close (couple of feet) connectivity may not work at all, it is more stable if
1. there's at least 6+ feet between them
2. no major metal obstacles on the way (like in my case there were garage gate made of sheet metal) that was blocking connectivity.
I also tried external antenna for Pine64 wifi (5Dbi RP-SMA Antennas), which did not help much. WiFi works okay in the room
if pine is plugged in in one corner of the room and i connect to it from another corner.
ps. Interestingly enough, same garage gate is not an obstacle for RaspberryPI 3 wifi AP.
pps.I would look into syslog on pine64 to see if you can find some clues why connectivity is not established ...
Okay, I don't know what I did differently when I retried starting up the hotspot this time, other than running hostapd from the command line instead of as a daemon, but I was able to connect my phone to it with no problem. Speedtest.net shows the speed to be much slower than my internet speed, but my plans for the hotspot is mainly for transfer between local devices, so if that's fast enough I won't mess with it further.
Now using the android 5.1.1 no TV. Easy to set the wifi and the connection is stable...
Also set the DC_in through the Euler bus today... might experiment again with linux images later on.
  [split] Better WiFi/BT module? moriel5 3 10,638 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,809 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,416 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,278 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,911 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,886 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 3,603 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 6,207 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,882 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,153 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
