Android USB camera support - Android 7.0
#21
(09-24-2016, 04:19 PM)ayufan Wrote: Ok, CSI camera does work. I can also make make photos Smile
Does it do video as well?
Backer #6878
shipment status: arrived
#22
Should I test it too? Smile
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#23
Please! I'll hopefully have some new camera code for USB UVC camera support soon.
Backer #6878
#24
I've been playing around with Android 7.0 ver 1.7 build 54 Android TV edition, and a Logitech c920 1080p USB camera.
The camera seems to be detected by Linux:
[   79.039894] uvcvideo: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[   79.053432] input: HD Pro Webcam C920 as /devices/soc.0/1c1a000.ehci0-controller/usb1/1-1/1-1:1.0/input/input8
[   79.068860] usbcore: registered new interface driver uvcvideo
[   79.076206] USB Video Class driver (1.1.1)
[   79.111909] gspca_main: v2.14.0 registered
[   79.121520] init: write_file: Unable to open '/sys/devices/soc.0/cpu_budget_cool.16/roomage': No such file or directory
But it can't be used by neither Skype nor Hangouts. This is what I get when I try to make a video call in Hangouts:
Skype says "Fail to connect to camera service".
I've attached a logcat
.zip   logcat.zip (Size: 81.69 KB / Downloads: 742)
#25
(09-17-2016, 03:25 AM)mikey0000 Wrote: Hi all,
Been working on getting the camera module up a firing. Tonight I had success and got my logitech 615 webcam opening in a camera app. However it probably means that the himax 5mp camera won't work with these changes. Just out of curiosity how many people here have the himax 5mp camera? It should be possible to support both but as I don't have one I can't test it.
Will post a link to the module when its a bit more ready flag that here it is and eventually it will end up in Ayufan's Android builds.
To use the module ALPHA
https://drive.google.com/open?id=0B3jDRH...UtmcmVVckE
run adb remount
adb push 32bit/camera.tulip.so /system/lib/hw/
adb push 64bit/camera.tulip.so /system/lib64/hw/
and also everytime you start
lsmod and look for uvcvideo or ls /dev/ and look for video0
if they are not there do the following
adb shell insmod /system/vendor/modules/videobuf2-vmalloc.ko sorted in latest build, uvcvideo too
adb shell insmod /system/vendor/modules/uvcvideo.ko  (assuming kernel support)
---> these two last steps should be fixed eventually in a new os build latest Ayufan has fixed this
You should at least get a video feed with this module.
Bug Reports:
- app your using ( e.g skype, camera app)
- Device your using (camera not pine)
- adb logcat with errors
- steps to reproduce
as always I will not be held accountable if your pine melts down because you followed these instructions!
Dear mikey0000,
The module https://drive.google.com/open?id=0B3jDRH...UtmcmVVckE  can't be download.
Would you please send it again?
Thanks,
Kind regards
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,170 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 564,893 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 45,871 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 29,236 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,480 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,809 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,479 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,997 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 381,309 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,729 02-26-2019, 11:58 AM
Last Post: Twistedx
