Question regarding Playbox case
Hi!   I received my Playbox case and was able to connect everything together with the help of Bob Carlson's video at https://www.youtube.com/watch?v=DTCIiChX...e=youtu.be .   One thing Bob pointed out in his comments was the inability/difficulty to swap the microSD card if the case is snapped closed.   I was thinking about acquiring a microSD extension cable to plug into the microSD port on the board that could feed out the case opening where the USB ports are accessible so that I could easily swap out the card without having to re-open the case.  I am not sure if this would work or not.  Could someone please let me know their opinion on this?  Thanks!
hi, yes, micro SD extension cables are available...  this is just one.
Hi Mark! Thank you for your suggestion. I went ahead and ordered a similar cable to the one you suggested and it just arrived today. I plugged it in to the microSD slot on the board, placed my microSD into its SD holder and plugged the SD holder into the other end of the cable. Powered up and it seems to work just fine! :-) This should make it easier to swap out OSs. Thanks again!
(09-13-2016, 05:50 PM)jeffrey_ring Wrote: Hi Mark!  Thank you for your suggestion.  I went ahead and ordered a similar cable to the one you suggested and it just arrived today.  I plugged it in to the microSD slot on the board, placed my microSD into its SD holder and plugged the SD holder into the other end of the cable.  Powered up and it seems to work just fine!  :-)  This should make it easier to swap out OSs.  Thanks again!
You are welcome; I'm glad it worked out ok for you, and others will be glad too, because anyone attempting to use the ABS playbox will run into this same problem.
Photo Weatherproof case build ltorsini 12 41,556 07-07-2026, 07:01 PM
Last Post: ltorsini
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 99,701 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 7,323 11-12-2019, 04:52 AM
Last Post: xalius
  Playbox with DAC llungster 0 5,070 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 20,315 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,869 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 30,515 07-18-2017, 10:39 AM
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 17,212 07-16-2017, 01:51 AM
Last Post: selina3
  A case with active cooling for 1Gb pine64 ishwest 5 16,691 06-28-2017, 04:05 AM
Last Post: ishwest
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,624 06-17-2017, 01:29 AM
Last Post: pfeerick
