Android TV
Hi there.
If the pine 64 is compatible with android, will it be with android tv? Is there extra steps to make an android tv system image?
Thanks!
Android TV is just software for an entertainment hub, for actual TVs or media players connected to a TV.
As long as you can get the individual packages, someone could make an Android image for you.
In terms of requirements, it requires Android 6.0 (http://forum.pine64.org/showthread.php?t...d=24#pid24).
(01-07-2016, 04:07 AM)taros Wrote: Android TV is just software for an entertainment hub, for actual TVs or media players connected to a TV.
Just to add, that the Pine64 won't support Android 6 at launch, but it is planned.
Not only for my curiosity... as I want to use the PINE64 as an HTPC with Android TV and Kodi...
Android TV is an additional software loaded with start?
Or an adaption of basic Android firmware?
IMHO Android TV doesn´t require Android 6.0 - it works in my NVIDIA Shield Android TV with Android 5.1.
But it is expected to have a better experiance when upgraded to Android 6.0
Hope you can give some more in-depth information.
best regards from Germany :-)
Dietmar
Android TV is a marketing term for software similar to Kodi that is integrated into Android. To make it work on the Pine64, a developer or two need to figure out how to get the packages and install them. As long as there are no special hardware requirements or licencing issues, the work is feasible.
Sent from my XT1032 using Tapatalk
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,427 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 604,117 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 49,870 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 31,781 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,562 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,107 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,474 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,665 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 407,024 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,421 02-26-2019, 11:58 AM
Last Post: Twistedx
