Z-Wave module pinout to make it compatible with Pi b+
#21
You can see L1 (maybe an inductor as the L suggest but too tiny for me) upper the connector of the adapter on the picture.
Envoyé de mon SM-N9005 en utilisant Tapatalk
Thx Etienne,
Pine64 - 2Gb + Z-Wave (EU) + abs case
[url= http://www.etiennebretteville.com][/url]
(09-07-2016, 06:02 AM)ebretteville Wrote: There is resistors on it. And to be honest the board with the adapter doesn't fit in the official pine64 abs case.
I still don't see why the Z-wave module could not be fitted directly to the 40 pin adaptor board. A few SMD resistors shouldn't be such a big problem on a board of that size.
You have GOT to be kidding me ???!    (people are going to be grumpy)
Apparently not: http://forum.pine64.org/showthread.php?t...4#pid19264
(09-07-2016, 06:33 AM)ebretteville Wrote: You can see L1 (maybe an inductor as the L suggest but too tiny for me) upper the connector of the adapter on the picture.
Strange. The Pine64 shop shows no adapter board:
[Image: images?q=tbn:ANd9GcQf2RE4P3u4X2PlLLtTOqx...49WASOm2NQ]
(Nor do they show the antenna coil)
Backer #16374 - KS funded January 23rd 2016 - Backerkit funded on March 10th 2016 - BOARD RECEIVED ON JUNE 29th - BACKERKIT ORDER FULFILLED ON SEPT 8th
The US version does not go on the EULER bus, it does on the pine bus, and makes the rest of bus useless, as well as the top of the case. A little disappointed in that.
Mark, you have to use the adapter board as it contains three Resistors and the inductor, so it is not just about laying the Z-wave board flat.
(09-07-2016, 07:53 AM)mdsutton Wrote: Mark, you have to use the adapter board as it contains three Resistors and the inductor, so it is not just about laying the Z-wave board flat.
Great.  Really nice.
@ebretteville: are you using the US or EU version of the module?
My (EU) module is still in transit, I won't get my hands on it for another week or so.
EU version
Thx Etienne,
This is the previous version that using Mitsumi ZWave chip. Since Sigma Designs no longer selling the ZWave chip to Mistsumi, we force to use the Sigma Designs module.
(09-07-2016, 05:35 PM)tllim Wrote:
(09-07-2016, 07:14 AM)bonterra Wrote: Strange. The Pine64 shop shows no adapter board:
But why bother with a removeable adapter board, why not solder the Z-wave chips directly on to the adapter?
Can the Sigma module be used at all without the adapter?
He isn't kidding. My case and zwave module arrived this week also (exactly as pictured above but NOT like the one in the shop). It remains to be seen how well it will (or will not) work, but if you trim the 2 interfering lid reinforcement ribs out with a dremel and let the lid bend the pins a little, it will go in the case. I'm disappointed, but less grumpy now that the box is closed. On to the next step...
-greg
-greg
hi greg, what I would do is to de-solder the connector from the z-wave module pcb.  Then, solder a ribbon cable of what-ever-length between the module and the connector;  fasten the z-wave to the case away from hand-holds with velcro stickies, and plug the connector into the board.
Sad Z-Wave and openzwave+node-openzwave-shared saro 2 10,219 09-01-2017, 05:22 AM
Last Post: saro
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,369 03-26-2017, 06:03 PM
Last Post: B34N
  What cameras are compatible with that ribbon connector? nayrenitnatsnoc 1 6,664 02-18-2017, 11:50 PM
Last Post: dkryder
  KICAD Quick Lib and Module Generator mbt28 1 7,880 02-12-2017, 10:45 PM
  Z Wave Module and still using GPIO bang 2 9,561 01-16-2017, 03:12 AM
Last Post: bang
  Z-Wave US module with adapter aegrotatio 4 12,445 01-08-2017, 12:03 AM
Last Post: aegrotatio
  RaZberry Module (z-wave) need support to get it working! Luxus 13 30,906 11-03-2016, 02:04 AM
Last Post: Luxus
  Z-Wave module problem vintagewaffle 0 3,859 10-26-2016, 10:50 AM
Last Post: vintagewaffle
  Raspberry Pi and Arduino accessories compatible? Krowyn 6 17,058 10-08-2016, 10:36 AM
Last Post: rohan
Video Australia/New Zealand Z-Wave module Jnimmo 46 98,519 10-02-2016, 02:25 PM
