Z-Wave module pinout to make it compatible with Pi b+
Yes but mine has a raspberry gpio adapter
Envoyé de mon SM-N9005 en utilisant Tapatalk
Thx Etienne,
Pine64 - 2Gb + Z-Wave (EU) + abs case
[url= http://www.etiennebretteville.com][/url]
(09-06-2016, 11:26 PM)ebretteville Wrote: Yes but mine has a raspberry gpio adapter
I'd like to help you ...
... maybe you could give me a link to what you're 'really' using !
It's the one from the pine64 official pack. That's why I gave you a link on shop.pine64.org[Image: f86db21479c3b3a9d27f2f75ae977d1c.jpg][Image: 0fb9e30f998fe9cbb7c9c4c788d7a780.jpg]
Thx Etienne,
Clearly, the lower module was designed for the later PI bus, not the PI(1); its a 40 pin layout.
...  the square pin is typically pin(1) so the alignment of the lower module would be with the module to the inside of the pine board...  I can see the Rx and Tx pins labels on the end of the lower module; so its accessing uart2 ( ttyS2 ) on the PI bus... what are the other pin names on that board ?  Also, clearly this board was not designed for use with any PI ( let alone the PI(1) ) and was designed for use on the Pine board. Supposedly they have been tested/  what is your question about this module ?
If you want to know can you plug it onto the PIb  ( PI(1) )  by aligning pin(1), then yes. The module probably won't work, but it won't break anything on the PI.  The PI's uart is on the same pins, but its called ttyS0, or serial0, ttyAMA0,  ...  as for the other pins ( depending on which ones are being used ) it may are may not work plugged into the PIb.  You might want to take a meter (with continuity checker, and the lower module only) and trace where each of the upper module pins goes one-by-one.
Another way to say this is, if you trace the lower module to any of the pins higher than pin 26, the board is not going to be at all compatible with the PIb (twenty-six pin layout).
But, just because you trace all of the pins to the lower 26 pins (1 - 26) does not mean it will work !
(09-07-2016, 12:01 AM)MarkHaysHarris777 Wrote: Clearly, the lower module was designed for the later PI bus, not the PI(1); its a 40 pin layout.
Sure this is what i was going to do but if I had the schematic I can avoid  the continuity task... But as there is no documentation on this module, I'm going to do the job.
Thx anyway for your time.
Thx Etienne,
Jeez, are you serious? Do we need to use an adapter board to fit the Z-wave module to the Pine?
Backer #16374 - KS funded January 23rd 2016 - Backerkit funded on March 10th 2016 - BOARD RECEIVED ON JUNE 29th - BACKERKIT ORDER FULFILLED ON SEPT 8th
(09-07-2016, 05:13 AM)bonterra Wrote: Jeez, are you serious? Do we need to use an adapter board to fit the Z-wave module to the Pine?
yeah, right?   ... only if you want it to lay flat !!!     Blush
Why not just put all of it on the adapter board then? Less height and fewer components.
Are there any other electronic parts on the adapter board except for the two connectors?
There is resistors on it. And to be honest the board with the adapter doesn't fit in the official pine64 abs case.
Thx Etienne,
(09-07-2016, 06:02 AM)ebretteville Wrote: There is resistors on it. And to be honest the board with the adapter doesn't fit in the official pine64 abs case.
You have GOT to be kidding me ???!    (people are going to be grumpy)
Sad Z-Wave and openzwave+node-openzwave-shared saro 2 10,014 09-01-2017, 05:22 AM
Last Post: saro
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,166 03-26-2017, 06:03 PM
Last Post: B34N
  What cameras are compatible with that ribbon connector? nayrenitnatsnoc 1 6,505 02-18-2017, 11:50 PM
Last Post: dkryder
  KICAD Quick Lib and Module Generator mbt28 1 7,655 02-12-2017, 10:45 PM
  Z Wave Module and still using GPIO bang 2 9,326 01-16-2017, 03:12 AM
Last Post: bang
  Z-Wave US module with adapter aegrotatio 4 12,114 01-08-2017, 12:03 AM
Last Post: aegrotatio
  RaZberry Module (z-wave) need support to get it working! Luxus 13 30,301 11-03-2016, 02:04 AM
Last Post: Luxus
  Z-Wave module problem vintagewaffle 0 3,776 10-26-2016, 10:50 AM
Last Post: vintagewaffle
  Raspberry Pi and Arduino accessories compatible? Krowyn 6 16,736 10-08-2016, 10:36 AM
Last Post: rohan
Video Australia/New Zealand Z-Wave module Jnimmo 46 95,701 10-02-2016, 02:25 PM
