No playbox yet, Sooooo....
I took an old desktop pc case I had, stripped it down and mounted my Pine64 in it. I stripped the power supply down to the external cord connector and switch, allows me to switch it on and of easily. Mounted a small cpu fan under the board for a little cooling, and left the original case fan. Wired in a power strip for the power supplies for the pine64, cooling fans and speaker power. Wired up the front usb ports to a usb plug for the pine so both front usb ports on the case work. Then mounted a speaker on the front of the case. Granted, I would have to remove the cover to swap out sd cards, but i'm primarily using it to learn ubuntu, so not an issue right now. Lol, takes up some space, but hey, it works.
Pretty cool, like it
Sent from my SM-G900V using Tapatalk
Very clever. I like it. Now.... where did I stash that old computer?
very nice...
  Playbox with DAC llungster 0 5,069 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 20,314 02-22-2019, 03:24 AM
Last Post: GaryFunk
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 17,212 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,624 06-17-2017, 01:29 AM
Last Post: pfeerick
  playbox and camera jpfaubert 1 6,720 03-07-2017, 12:51 AM
Last Post: MarkHaysHarris777
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 10,025 02-12-2017, 10:17 PM
  Playbox battery charge jdmwrx94 12 30,746 12-20-2016, 07:19 AM
Last Post: Toriless
  Playbox case orderable? schindlb 8 22,082 10-02-2016, 08:20 AM
Last Post: schindlb
  Solution to awkward playbox cabling Visionrx7 2 7,238 09-13-2016, 11:46 PM
Last Post: Visionrx7
  Question regarding Playbox case jeffrey_ring 3 8,756 09-13-2016, 07:39 PM
