Feature u Think we need to improve?
Audio
51.16%
22
Rear Video
13.95%
6
GPS
34.88%
15
43 vote(s)
Pine64 Head Unit
#51
For those that have done this, how are you mounting the LCD touchscreen in the car? The only way I see is to use double sided tape to tape it to something flat (lexan, etc) then mount the lexan into the factory mounting spot. I don't see any place to securely screw into, which I would prefer using screws to mount it as tape would be a semi-permanent solution that may wreck the screen should you have to remove it from the mount.
#52
(07-17-2016, 06:32 PM)CanadianIceTech Wrote: For those that have done this, how are you mounting the LCD touchscreen in the car? The only way I see is to use double sided tape to tape it to something flat (lexan, etc) then mount the lexan into the factory mounting spot. I don't see any place to securely screw into, which I would prefer using screws to mount it as tape would be a semi-permanent solution that may wreck the screen should you have to remove it from the mount.
I haven't gotten my lcd yet but I'll take a look when I do. Hopefully that will be soon. I would guess that some sort of plastic bracket that can clip on would be the best solution.
I would look at the drawings for the play box (that's what they are calling it right?) And maybe take the front piece and then draw a new back piece that has the mounting options that you want and then use a 3d printer to make your bracket.
Sent from my XT1575 using Tapatalk
#53
Video
Hi Guys Well here i have the Review Of my Package  :Big Grin
i hope u like it
soon i'm goint to be working of our project so don't worry
ill start testing some apps
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
#54
Also, has anyone found any android versions that boot faster? A 1 minute boot time would kinda suck in a car
#55
(07-19-2016, 10:16 AM)CanadianIceTech Wrote: Also, has anyone found any android versions that boot faster? A 1 minute boot time would kinda suck in a car
use a large battery and put the unit to sleep instead of shutting it off?
a battery big enough to go a week or more in sleep mode
#56
Sorry guys but i had a little problem with the LCD
it came Brooken Sad
i alreadly contacted @tllin but no answer yet to solve this
i wanted to start working with the pine on the Head Unit Dev but no chance now
so i'm now working on linux and testing some of the GPIO control examples and setting all up
hope to have u good news soon
please start working on testing some of the devices Big Grin
and apps that we can use Smile
By. Zoidiano0!
Installed:
Netbeans 8.1
#57
As a starter you might want to have a look at http://i-carus.com/shop/ , scroll down to the parts where you find a "2DIN housing "iCarus" with integrated switch on/off toggle, rotary button and active USB hub". Or go to http://www.carav-parts.com/ and search for your car brand and model.
There is certainly more out there and collecting these parts here would certainly be useful.
#58
Hello! Since my previous reply I didn't worked a lot on my Car PC project, but I've ordered a 7" touch panel usb, and an usb GPS receiver, so I hope they will works with the pine Smile
And since my previous reply, I've changed my car, and my new one have a 2din, so I'm thinking of building a full radio in 2din enclosure
So I've looked to the touchscreen they sell on the store, but a lot too big to fit 2din, so I've looked at the datasheet and found the LCD they use (Feyiang FY07024DI26A30-D, about 15$ on Aliexpress).
With this one I could use the direct DSI connector, no longer need of a screen controler.
But I need touchscreen, and I can't found the reference of the touch panel they use with the touchscreen pine64 sell. Anyone have informations about that?
I will keep you in touch for my GPS receiver Wink
#59
helo @ipsw
hope to see how that build works Smile please post results about the GPS
the codes i can read from the tp are
XDX20160426
HK70DR2459-COF
THE DRIVER CHIP IS A
GOODIX GT911
THE PIN ORDEN IS
RST
INT
SCL
SDA
VDD
GND
PM if u want Big Grin
hope to see news about your build
please post pictures Smile
By. Zoidiano0!
Installed:
Netbeans 8.1
#60
Hello everyone! First let me say that I a complete noob when it comes to the Pine64 or any other small computer.  My background is industrial computers (CNC, Automation, and Robotics, and DAQ) using windoze and MSDos. Since I retired, yes an old geezer, I decided to pick up a Pine64 to tinker with to learn Linux and Android.
I have a need for such a project such as this head unit. The wife and I are building an Expedition Vehicle. One of the open items on the list was an integrated navigation and communication device. I have looked at doing a MiniPC and off the shelf software, but find there is always something lacking plus the problem with dust and dirty environment cooling.
A few items I would like to see:
I maybe asking too much of one Pine64.
It would be nice to add a front camera using the same hardware and record both front and rear like a dash cam stored on SD card or SSD.
12 VDC compatible I/O board or boards. Possibly something controlled via I2C or CAN bus for remote I/0 using the I2C POT board. Have an idea for remote relay box for accessories also would like to monitor my auxiliary batteries for voltage and current draw.  Found these, but know nothing of the company.
http://www.horter-shop.de/en/12-i2c-assemblies
http://www.horter-shop.de/en/i2c-din-rai...60714.html
http://www.horter-shop.de/en/i2c-din-rai...60721.html
http://www.horter-shop.de/en/i2c-din-rai...60745.html
http://www.horter-shop.de/en/home/93-kit...60752.html
Picture a screen with virtual switches and digital info. Saves a lot of additional wiring and switch mounting. I don't know the distance limit on I2C this is the reason I mentioned CAN bus.
Add a Griffin PowerMate Bluetooth via A2DP and AVCRP. Less reaching for the screen. Can use one button to scroll and select.
https://griffintechnology.com/us/product...-bluetooth
I like the suggestions so far for Audio and GPS.  Plenty of navigation apps with offline maps available already.
I have plenty of mounting space. Maybe splitting this into two head units one for audio, navigation, and DVR and the second one for the accessory switch panel with DAQ.
I could even do a third just for the DVR if it gets to be a problem.
Sorry for being long winded but a lot of ideas doing the roundabout in my head not knowing what direction to turn.
  Pine64 as squeezebox touch replacement Learnincurve 12 42,720 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 14,482 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 6,694 08-06-2020, 12:05 AM
Last Post: tuaris
  PINE64 to allow use of SATA disk on network/FTP mwelbourne 10 26,601 11-18-2019, 04:09 PM
Last Post: evilbunny
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 62,680 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 6,063 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 63,242 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 15,119 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 11,122 02-01-2018, 07:49 AM
Last Post: davidbrucs
Photo Nextcloud running on Pine64 gbjensen 1 9,259 01-18-2018, 05:51 AM
Last Post: Luke
