(potential) work-around for Playstore authentication issue
#21
(07-10-2016, 01:23 PM)Raslin777@gmail.com Wrote:
(07-07-2016, 11:39 AM)tllim Wrote: I plan to make a new Android code release on next two days with GSM 5.1r4 package, and this include latest App Store code. hopefully this can resolved the Play Store mystery.
I would bet this definitely will fix some issues. Is there any documentation on how to build the android os from scratch. I would love to check out some stuff as well. Is there a git somewhere?
Try out pas s two days seems works well, I will upload the build tonight. We are currently working with one third party Android developer on document his progress of build the Android OS from scratch. I will post when he release the document.
#22
(07-12-2016, 03:58 PM)tllim Wrote: Try out pas s two days seems works well, I will upload the build tonight. We are currently working with one third party Android developer on document his progress of build the Android OS from scratch. I will post when he release the document.
Hello, can you tell me where I can find the latest Android image/build that includes the new Play Store code?
I am having the same issue: I cannot install any apps from the play store. (Error DF-DLA-15)
#23
Same here. :-( DF-DLA-15 when trying to download TED app.
This is using the new 20160711 build (rooted 16GB), with original settings, except my Google account.
The clock is accurate to the minute. The RTC doesn't correct millisecond errors, but even when I correct them with the Clock Sync app, the issue remains.
NexusDude of Central Texas
  • Setup: Pine64+ 2GB, On/Off button, RTC battery, 5V fan, LG 1.8A power adapter, Cat6 Ethernet, HDMI to TV, USB keyboard & mouse, SanDisk Ultra mSD "32GB" (28.7GB). Using Win32DiskImager.
  • Best OS experiences: Debian XFCE >> Android Lollipop > the rest
#24
Hi, I wanted to reply back for anyone who might read this and who had the same problem.
I re-flashed the SD card with the 'current' Android image: http://files.pine64.org/os/android/andro...4-64GB.zip and it seems that the Play Store is now working. I can install apps.
I tried 2 ways: 1) with a personal gmail account and 2) with a work-related account which has Google Apps for Work device policy limitations (the IT admin at work can limit which apps to install, require a password, etc.) It works both ways.
So I hope it continues to work. I don't know which Android image shipped with the Pine64, but that is the image I tried first, and had the Play Store issues.
Besides re-flashing with the current image, I made sure to download the image for HDMI Video Output. My Pine64+ came with the 7" touchscreen display, so I am assuming the Android image on the SD card was for the LCD touch screen. I have my Pine 64+ hooked up to a LED computer monitor via HDMI. So now the menu buttons are in the right place. I don't know if this made the Play Store work or not.
I hope this helps someone out there.
#25
(06-16-2016, 05:49 AM)the stilton helmet Wrote: Hello Everyone.
I too have had some issues with the playstore, receiving" DL5-" and "auth error" messages even though my profile is logged into google.
I will state at this point that I`m using android 5.1 and i have a twin AA clock battery pack fitted.
However, I have noticed that my device registers the correct time about 6 seconds after bootup. The time zone I had to change manually. This was before I fitted the battery pack.
I followed the "add account" instructions (settings/accounts/ +add account/ google)
I then entered my existing account email and clicked next.
the page refreshes and a little line of type in red says "account already exists". Below this is a blue link that says "having trouble finding your account?". I clicked it.
It then asked for my country and mobile (cell phone ) number. I typed it in. clicked next. The screen then asked for my name - first and last. This entered, I clicked next.  A white box appeared - "google will send a code to .(your number) to verify your account". I clicked verify.  A few seconds later the screen brought up a G -code verication box. An sms message arrived a moment later on my phone and I entered the code. Validated.
I have switched the device off and on twice now and it continues to work. longer trials may yield different results.
If this works for you, then all credit should go to those have posted in this area before myself.
Keex, luke, NexusDude and anyone else I have overlooked.
All I did was blunder into this. I would not have arrived at it without following their instructions.
If it fails, blame me.
Firstly, I never have had any problems with system time with no battery after changing the time zone.
Secondly, I had this DF-DLA-15 problem a lot.  Go to setting, then the Applications Manager and select "Google Play Services", stop the application and clear the cache which will reset to 12K then clear ALL DATA (the button above the cache) and to 0 bytes and REBOOT or it will still fail.  When the system is started again Google Play will work again.  You have to do this every time it occurs.  I had to do it a lot at first.  Also, install GMail first it will for an much need update to another application to occur or you can not run many Amazon applications.  I have fixed the DF-DLA-15 many times and doing those 6 steps has always fixed it.
Next, If you have a GMail account log into it.  You will have automatic access to Google Play.
Finally, some application may be block because you have regional issues.  Go to https://apkpure.com/ and download and run the .apk file for those few applications.
(07-14-2016, 01:21 PM)cantcode Wrote: Hi, I wanted to reply back for anyone who might read this and who had the same problem.
How do I burn to a 128 GB card?
(06-26-2016, 09:57 PM)CypherColt Wrote: My solution was to uncheck the Sync for apps and check it again, without even exiting the Google Play app. Worked right away for me.
Hope this helps!
Edit: (to specify)
I went into Settings, Accounts, Google, my email, i disabled App Data sync, and then enabled it again.
That did not work for me but ...
(06-30-2016, 12:45 AM)NexusDude Wrote: This continues to be an issue for my Pine64.
For my Pine64, it occurs consistently, sort of.
  • Affects all Android images -- rooted, so-called "un-rooted", RemixOS
  • GP Store will always work, initially, upon booting for the first time
  • GP Store will eventually stop permitting app downloads and app rating submissions. Even if it's working now,  give it time...
  • Once it fails, it continues to fail, until you apply a work-around fix, or re-image.
  • Once a workaround fix stops working, it continues to fail. You must try a different fix, or re-image.
(The DD images of Android all test as rooted.)
What varies:
  • The length of time that GP Store works. When you boot for the first time, or succesfully apply a workaround fix, it will work... but eventually it stops. You may get downloads & rating submissions working for hours, or only seconds. Typically, you can get in a few installs, while it's working, before it quits again. You many only get 1 install in, though, or none at all. In a one hour session of Android, you may apply fixes several times, without rebooting.
  • Sometimes, workaround fixes stop working.
  • Pop-up vs. Notification. How the app informs the user of failure varies. A pop-up error message likely mentions DF-DLA-15. An Android notification always mentions authentication failure.
  • Multiple notifications vs. 1 notification maximum -- sometimes, you must clear the notification to be informed of future errors; other times, you can get multiple notifications
  • Various fixes, sorted by speed:
  1. Settings / Accounts / Add New Account / Google
  2. Settings / Accounts / Add New Account / Google / enter gmail of existing Google account
  3. Settings / Accounts / select account / Remove Account / Add New Account / Google / enter gmail of account you just removed
  4. Clearing GP Store and GP services caches, rebooting
  5. Wiping the Dalvik partition, rebooting
  6. Reimaging your microSD card, booting
Other things I've tried, that never helped or seem unrelated to this issue:
  • Gmail accounts with 2-step verification, vs. those without
  • Using only a single Gmail account, vs. using multiple Gmail accounts
  • Using Gmail accounts with Play Store credit, vs. those without a payment method
  • Rebooting
  • Using other images of Android
  • Using a time app to document time clock differences
  • Turning account syncing off/on
  • Various power adapters
What I have not yet tried:
  • Heat sinks / fans / cooling my house more
  • RTC battery
  • Shorter Cat6
What I've had trouble trying:
  • Wi-fi dongle
  • Mock Location -- there doesn't seem to be a way to set this
  • Using a time app to reset the time from NTP
Few have voiced their frustration on pine64.pro, which seems odd, considering the various threads on this issue. Maybe they didn't want to bother registering a new ID there?
Clearing the Cache along does NOT work, you MUST also click the clear all data button and reboot.
#26
I'm hitting the Google Play auth bug all of the time too. This is very annoying and it needs to be fixed ASAP.
As a work around, this has worked for me every time.
Once it fails, go into Settings/Accounts.
Click on the Add Account Google item to add a new account
type your existing Google account into this new account
that will generate an error saying it is already registered
now it will work again for a while....
wash rinse repeat....
#27
(07-25-2016, 10:41 AM)jonsmirl Wrote: I'm hitting the Google Play auth bug all of the time too. This is very annoying and it needs to be fixed ASAP.
Tried this just now and it works..a royal pita to do it every time, but if it is a consistent workaround, as sad as the idea may be that one has to do this every time, its better than nothing.
I remain somewhat amazed that this issue hasn't been fixed by now.
#28
I have switched the device off and on twice now and it contiunes to work. longer trials may yield different results.
I tried your method and work out for me too
Thank you!
#29
Seriously every time?? It shows that I'm logged in in the settings menu, why is it saying I need to log in? I am not about to remove and re-add my account every 10 minutes or every time I need to download something else... The more I get into this board, the more frustrations I'm discovering.
#30
(09-01-2016, 09:52 AM)Chisel_86 Wrote: Seriously every time?? It shows that I'm logged in in the settings menu, why is it saying I need to log in? I am not about to remove and re-add my account every 10 minutes or every time I need to download something else... The more I get into this board, the more frustrations I'm discovering.
No.  If your time is set correctly, and if your TZ (time zone) is set correctly, and if you're logged into Google and the playstore, you will NOT have this issue.  I have two Android boxes, one playbox, the other I call my play desk, and they both work fine...
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 7,624 11-16-2017, 02:14 PM
Last Post: Skivholme
  Playstore Selections Limited in 7.1 TV CharlieB 2 6,146 10-19-2017, 12:24 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 7,038 08-29-2017, 12:05 AM
  VPN issue on Pine64 pinea64.edison 4 10,409 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 19,841 06-02-2017, 01:32 PM
Last Post: Bob123456789
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 11,244 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,184 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 9,867 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,463 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 3,973 09-11-2016, 06:29 AM
Last Post: ameth
