App compatibility issues with pine64
This weekend I started to play with my pine. I am using Android atm and I tried to install 3 apps. Unfortunately only 1 was successful.
Until now I didn't get any error message or authentication issues. But I can't download the apps, because the play store tells me the device is not compatible. Is there a fix or workaround?
Te apps are:
- telfort it online (IPTV app from TV provider)
- Cbox HD
You could try to locate the .apk files by googling it. Or you can spoof your device-id to make google store identify the pine as something else. (The spoofing trick require root access to work).
Thanks, I'm 'new' to Android. So now I found a couple of apk's. But they are not hosted by the play store. Is it still safe to use them?
(07-06-2016, 06:30 AM)Boring Wrote: Thanks, I'm 'new' to Android. So now I found a couple of apk's. But they are not hosted by the play store. Is it still safe to use them?
You can never be 100% sure about that. But if you are sceptical you could get an app called lucky patcher and backup the apks from another device that is compatible with those apps (like your phone or something) and then copy the apks to the pine and install them there.
  Issues with SD Card and Running Android Twistedx 0 7,551 02-26-2019, 11:58 AM
Last Post: Twistedx
  Pine64+ 1G and Pine LCD with Android 6.0.1 Tanveer 0 8,522 09-03-2018, 05:05 AM
Last Post: Tanveer
  Youtube TV experience/ screen resolution issues gubaguba 0 3,537 02-22-2018, 09:12 AM
Last Post: gubaguba
  2nd ethernet in PINE64 with android daniele 2 7,179 12-07-2017, 05:09 AM
Last Post: daniele
  Pine64 + Youtube TV Performance mikedice417 0 3,716 11-25-2017, 10:36 AM
Last Post: mikedice417
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 7,624 11-16-2017, 02:14 PM
Last Post: Skivholme
  Android 7.1 reboot on Pine64 2GB rkbren81@gmail.com 2 7,062 11-07-2017, 06:33 AM
Last Post: rkbren81@gmail.com
  Connecting external DVDRW drive via USB to Pine64 galbez 4 10,769 10-12-2017, 12:35 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 7,037 08-29-2017, 12:05 AM
  Boot hangs on pine64, how to debug? olh 1 5,900 08-29-2017, 12:04 AM
