reset wifi hardware/driver when it dies through console on pp?
Hi
question:
My wifi sometimes just dies, and i was wondering is there a way to reset the hardware/driver or something? like the modem reset command?
thanks!
(02-11-2023, 04:17 AM)tuxcall Wrote: Hi
question:
thanks!
Don't know if this will help, but try "sudo systemctl restart NetworkManager.service".
question:
thanks!
Yes, see below:
sudo rmmod 8723cs && sudo modprobe 8723cs
thanks! i'll try both those answers when my wifi drops/acts weird again
Thanks for sharing! This is what I am looking for
I am using Mobian on the PinePhone and sometimes, randomly after boot, the WiFi icon in the Phosh top menu is unavailable (grayed out).
A reboot can fix the issue. If we don't want to reboot, restarting NetworkManager did not work and the module 8723cs mentioned in this thread was not found.
By using the command lsmod I found the correct module, the solution was:
sudo rmmod rtw88_8723cs
sudo modprobe rtw88_8723cs
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,087 02-20-2025, 02:47 PM
Last Post: puffchumpy
  Wifi doesn't work after update nickolas 2 4,843 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 5,037 01-12-2023, 03:06 PM
Last Post: user641
  Wifi issue since last update and held back updates goku499 11 15,913 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Hardware VIdeo Acceleration on Mobian biketool 3 6,246 06-21-2022, 01:01 PM
  Problem with wifi kubussz 0 2,187 04-02-2022, 12:57 PM
Last Post: kubussz
  Anyone using a hardware token? p121458 13 22,435 01-17-2022, 03:24 AM
  wifi adapter not found.. why? b7l3wui26r 3 5,179 11-29-2021, 10:28 AM
Last Post: beta-user
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 58,563 11-02-2021, 03:42 AM
Last Post: AntonReiser
  Jerky wifi and bluetooth motox6 0 2,560 06-22-2021, 12:50 AM
Last Post: motox6
