Return of faulty board
Board I got is faulty somehow.
I tried every single image, tried phynix, winimage, DD on linux every single way on multiple SD cards (2GB, 4GB, up to 16 and even 32GB - more than 10 different SD cards)
No luck at all...
Sometimes I can see for bries second starting up logo (penguin with moving txt on screen) then dissapears and nothing else. Even red light goes down.
I have enough  of "fun" and I would like to replace board with the working one or return for full refund.
I've send email to support but no answer at all...
I understand guys are busy but if success of the board is too much for you to handle maybe its time to find someone that would do that for you.
Have you tried other PSUs and micro USB leads?
The fact that the red light turns off after a while leads me to believe you probably have an underpowering issue.
I'm working in a service center for a tablets, PC's etc.
I've tried many chargers and cables. (5V2A, 5V3A)
(06-15-2016, 05:13 AM)fdx Wrote: I'm working in a service center for a tablets, PC's etc.
I see.
I guess support is the only ones they can help you with troubleshooting or returning the board.
Good luck with that. It might take some time to get a response but they will contact you. At least they did in my case.
I'll give it to my tech to check the usb port on the board. maybe there is a really problem with power and the only think I did not test is the port on the board.
(06-15-2016, 05:27 AM)fdx Wrote: I'll give it to my tech to check the usb port on the board. maybe there is a really problem with power and the only think I did not test is the port on the board.
You can also try powering via the Euler Bus or Pi-2 interface as well, if you like.
Also, how did you burn the images? (PhoenixCard, Win32DiskImager, Rufus, dd)
And what microSD card are you using?
And what monitor/screen are you using?
  Alert status on 17track - return to proper cast hellojack 2 8,776 08-11-2021, 02:09 AM
Last Post: hellojack
Exclamation Got your PINE64 board yet? Post here! shockr 261 448,068 07-27-2016, 12:48 AM
Last Post: vinodmenon80
  Lost Board? rayzr8 35 66,516 07-10-2016, 11:19 PM
  When will my board ship? upartner 50 93,494 07-04-2016, 05:24 PM
Sad Where is my board? duane 4 10,258 07-01-2016, 07:52 PM
Last Post: duane
Photo Missing items, board without switches zzarko 7 14,990 06-29-2016, 07:23 AM
Last Post: damian1m
  Kickstarter claims I received board - not true. pedalman 2 6,350 06-21-2016, 08:52 AM
  No Pine64 board nor tracking number n0n4m3 5 11,707 05-16-2016, 07:22 PM
Last Post: scprosser
  Where has my board gone? paysondude 3 8,575 05-05-2016, 09:55 PM
Last Post: paysondude
  When can I expect my board - December Kickstarter backer dtc0419 3 8,376 05-03-2016, 05:35 PM
Last Post: Inuyasha
