Using the Pinetab2's PCIe slot
I am interested in using the PCIe connector in the pinetab2, however I can't seem to find a suitable ribbon cable for connecting to it.
The connection appears to be the the part labeled U7001 in the component sheet and it confirmed looking at the schematic (page 36) where the pinout of U7001 connector is given and it is referred to as NVMe PCIE 2.0.
The only connector I was able to find was the connector for the pinebook pro. The problem however is that this connector would place the card exactly on top of the battery where there is no room for a card.
Here I show the outline (white outline) of where the pinebook 2 adapter would be in the pinetab, and the ideal position where an expansion card would fit (green rectangle).
The idea is that there are several wifi/bluetooth cards that work with PCIe, with various different physical formats, and most of them are small enough to fit above or below the battery in the pinetab2. The only problem is just getting a cable that will allow it to fit in the right spot.
My two questions are whether anyone knows whether there is another source of the ribbon cable that is needed for this connector? If I could just find the ribbon cable with approximately the right shape, then I could use the adapter from the pinebook pro and move the battery slightly in the pinetab2 to get it to fit.
Alternatively, it could be possible to cut the ribbon cable and solder it again to give it a different shape, however for this I don't know what the tolerance would be for the change in impedence and possible capacitance (perhaps leading to cross-talk) between the wires in such a pcie connection. Does anyone know how carefully engineered a PCIe connection must be for something like a wifi card?
  PineTab2 spec for ddr and rth 0 2,951 12-09-2025, 08:28 PM
Last Post: rth
  Pinetab2 not starting Corconegre 12 24,066 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 4,287 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 16,748 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 4,023 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 7,128 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 5,654 01-07-2024, 10:58 AM
Last Post: JMoore
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 2,665 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 15,900 09-15-2023, 11:45 PM
Last Post: Ome Ko
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 9,525 09-06-2023, 07:43 PM
Last Post: bacon_dude
