The Mobian Phosh Experience
I have been using the Mobian Phosh partition for a while now. I count three reinstallations of it. But it has not faltered since the spring.
The latest news is that I installed the pinephonepro_support and pinephone_tweaks packages instead of the pinephonepro_tweaks package. The audio playback is not chancy now.
The installation gladly accepts a Bluetooth mouse, so a screen magnification of 100% is usable instead of 200%.
I was able to fix the missing keyboard symbols for the Linux consoles, but not for the Wayland windows.
The Web app still has a memory leak. My modified Megapixels  works, but it has lost its auto exposure capability. And the rear camera does not recover from suspension. The Camera app  works, as does the Voice Recorder.The Mpv app plays even vob video files when they are opened in the Files app.
(10-08-2023, 01:21 PM)mburns Wrote: I have been using the Mobian Phosh partition for a while now. I count three reinstallations of it. But it has not faltered since the spring.
Thanks for the update mburns,
Will give them a go as well Smile
  Experimental Mobian kernel patch for extended battery life teekay 15 17,130 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,138 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,861 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,270 02-25-2025, 08:27 AM
  Advice and experience on daily driving ppp JadenSki 19 18,535 01-09-2025, 04:14 PM
Last Post: mikehenson
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,218 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,255 10-28-2024, 10:46 AM
Last Post: Jite
  Command lines to remove the Phosh UI dorkydev 1 3,010 02-12-2024, 11:56 AM
Last Post: nekonosuke
  Disable the GDM service in Mobian. mburns 0 2,105 11-25-2023, 10:19 PM
Last Post: mburns
  Fix the Mobian Weather App mburns 0 2,004 11-07-2023, 10:01 AM
Last Post: mburns
