Advice and experience on daily driving ppp
Hello all,
I've been distro hopping on my ppp for a little while now. And I am trying to figure out which os I should settle down on, to use for a daily driver. So far everything I need to work has not all worked out of the box on any os, which is to be expected obviously. And based on other's experience I am fairly confident that I can get most, if not all, of the main things I want, to work. However, this will obviously take time and effort, and the question is 'which os do I focus on getting working?' So I thought I would ask the community for advice/personal experience. If ya'll could take the time to let me know: 1. if you daily drive a ppp, 2. what os you use, 3. what desktop interface you use, 4. what do you have working (eg camera, calls, sms...) and 5 maybe just some simple tips that might be helpfull. I would be extremely grateful.
The main things I would like to work (listed in order of priority) are: sms, calls, mms, gps, camera (to some extent at least), and usb-otg. I would definitely prefer plasma mobile above posh, but if I cannot get everything working on plasma then posh is the next best.
Thank you in advance!
(12-30-2024, 05:48 PM)JadenSki Wrote: ...
I use Arch Linux on EVERYTHING, so... I think Arch works well.
See this post for a complete install and setup.
https://forum.pine64.org/showthread.php?tid=18192
See this post for my experience on functionally
https://forum.pine64.org/showthread.php?...#pid118783
See this post for how I got Calls working on my PinePhonePro.
https://forum.pine64.org/showthread.php?tid=19428
2023 May through today my daily driver is a PinePhonePro running DanctNIX Arch with Phosh
2021 May through 2023 May my daily driver was a PinePhone running DanctNIX Arch with Phosh
I am running DanctNIX Arch with Phosh on a PinePhonePro and I have not had any of the issues people keep talking about. Calls, VoLTE, SMS, MMS, cell broadcast messages, voice mail, internet, Wifi, 4G data, mobile hot spot, calendar, calendar notifications, contacts, syncthing, Navigation with GPS and offline maps via osmin work, connecting Google accounts work, Groupme via firefox, Facebook via firefox ALL WORK. Calls, SMS, MMS all work from sleep.
I have not tested alarms from sleep. I have not tested any bluetooth items. The camera somewhat works with compiling my own packages. I currently use an Android device to take pictures and syncthing puts them on the PinePhonePro.
Device: PinePhone 32Gig (Used for building packages)
Device: PinePhonePro (Daily driver)
OS: DanctNIX Arch with Phosh
Carrier: USA - Patriot Mobile (T-Mobile SIM)
EG25 Firmware: Biktorgj 0.8.0
ADSP Version: 01.003
Yes, for 4 months now.
> 2. what os you use
Mobian Trixie. Stable/bookworm is just too out of date to have a good experience with
Plasma-Mobile
Currently have back and front camera working
Calls work great (sometimes audio/mic-gain related issue)
Wakes up from sleep since I flashed the community modem firmware
SMS works great
MMS I have not tested
Runs Wire and Signal for encrypted messaging, but you have to build it yourself
Works good for scrolling the internet
Get a backup battery to carry with you. The PPP still drains a lot of power due to poor power management and polling on Linux. It is getting better, but just do yourself a favor and get a nice big backup battery to take with you. You'll never run out of power!
Another tip is to get a nice USB-C docking bar, Pine64 sells one it works great. And an HDMI monitor to go with it. This has completely replaced my netbook for traveling. I can do all my work on my phone with the docking bar/external monitor. I also carry around a USB mouse and keyboard. Works great for my uses (Programming and SSH'ing into other boxes to do SysAdmin work).
@mikehenson and @pineconeuser ,
Thank you for taking the time to reply!  I will definitely try them out. @mikehenson Thanks for the step by step instructions, that is super helpful.
(01-02-2025, 09:27 AM)pineconeuser Wrote: > 1. if you daily drive a ppp,
> 2. what os you use
Plasma-Mobile
SMS works great
Where did you download your img for Mobian Trixie with Plasma? I can't find it anywhere. Thanks!
(01-05-2025, 04:25 PM)JadenSki Wrote: Where did you download your img for Mobian Trixie with Plasma? I can't find it anywhere. Thanks!
I sadly don't think there is one. I had to install stable, then change my `/etc/apt/sources.list` from stable to `trixie`, then:
  • apt update
  • apt upgrade
  • apt dist-upgrade
Before running `apt autoremove` I had to install `rockchip-support` and `pinephonepro-wifi` to prevent it from removing the drivers I was using.
Network manager broke and I had to use USB networking to finish the upgrade. I hope that helps. I should have documented the process, but alas I did not.
  • apt update
  • apt upgrade
  • apt dist-upgrade
Okay, that does help. Thanks!
After following your guide (which was very helpful btw), I got everything working (mostly) pretty well. The exception is mms. I cannot figure out why it won't work. Is there any advice you might have? I also use T-Mobile (though it is through tracfone, I don't see how this would effect anything though) and I use the same mmsc and apn as you in the video. I have calls, sms, and data, I just cant send or receive mms. That is the last thing required for it to be daily drivable for me.
(01-08-2025, 12:56 PM)JadenSki Wrote: After following your guide (which was very helpful btw), I got everything working (mostly) pretty well. The exception is mms. I cannot figure out why it won't work. Is there any advice you might have? I also use T-Mobile (though it is through tracfone, I don't see how this would effect anything though) and I use the same mmsc and apn as you in the video. I have calls, sms, and data, I just cant send or receive mms. That is the last thing required for it to be daily drivable for me.
" I got everything working (mostly) pretty well. " - That is good to hear!
In the matter of MMS, I think about 8 months ago, Chatty stopped looking at the system wide access points.
In chatty, go to
Preferences >> Protocal >> SMS/MSS >> MMS Carrier Settings and set those to
MMSC=http://mms.msg.eng.t-mobile.com/mms/wapenc
APN=Fast.t-mobile.com
In chatty, go to
I did that and still no mms, I suspect that it halfway works, because if I am sent a mms when the mobile data is turned off, chatty gives me the notification:
Quote:"chatty cannot process 1 MMSs..."  "mobile data is not configured"
 So I know it is at least somewhat receiving the mms. If I then turn on mobile data, and verify that the APN is "Fast.t-mobile.com" I never receive anything, or any kind of notification. If I am sent an mms while mobile data is on I don't receive it, or any kind of notification either.
It also fails to send any kind of mms as well, and chatty gives the message:
Quote:"Error Sending mms"
I dont know if I did something wrong, or if something is broken... I can't find anything about anyone having the same issue.
  The Mobian Phosh Experience mburns 1 3,978 11-18-2023, 08:21 AM
Last Post: crocspot
  Best SXMO experience on PPP getpoked 2 4,053 02-15-2022, 04:35 PM
Last Post: TheBlindEarthican
