Replacement battery for PineBook Pro
hi!
After 4 years of use, the battery of my PineBook Pro is really swollen, I should change it soon~ish.
Currently, it seems out of stock on the official store, and the European store doesn't even sell spare batteries.
So: has anyone had success procuring batteries elsewhere?
I haven't yet, but just a quick search turns up several that look like they would work, including this one
https://www.cdrtd.com/products/laptop-ba...-5pin.html
:wq
(09-25-2023, 07:12 AM)KC9UDX Wrote: I haven't yet, but just a quick search turns up several that look like they would work, including this one
That one specifically is not compatible, it's the 5pin variant, whereas the Pinebook Pro uses the 7pin avriant instead.
But cdrtd seem to have that one too.
But I don't know how much cdrtd is a reliable source for laptop parts. I've also found several vendors on AliExpress (random example), but same caveats apply: I don't know them, and I don't know anything about their reliability.
(09-25-2023, 09:44 AM)DrYak Wrote: I've also found several vendors on AliExpress (random example), but same caveats apply: I don't know them, and I don't know anything about their reliability.
Update regarding my battery problem:
  • still no answer from Pine64 themselves
  • but since then I bought one from Ali mentionned above, replaced it, charged it, seems to work.
I'll update in a few weeks whether this battery still holds charge or if it degraded too quick.
My PBP has been out of service for ages.
I hate to put it in the ewaste or turn it into yard art.
any new resources?
I've bought four from https://www.cdrtd.com/products/laptop-re...s-new.HTML
Two were recently, and arrived last week. The last mile shipping is always sketchy but that's not unique to this company.
:wq
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 7 10,872 10-05-2026, 12:42 PM
  pinebook pro dixplays vertical stripes WEF 2 5,217 03-23-2025, 03:31 PM
Last Post: WEF
  Replacement main board for Developers mozes 11 14,632 11-17-2024, 04:32 AM
Last Post: reukiodo
  Replacement touch pads Sb2024 0 2,847 11-14-2024, 10:05 PM
Last Post: Sb2024
  Bad replacement battery? chris88233 4 7,239 11-14-2024, 06:05 PM
Last Post: reukiodo
  Keyswitch scissors replacement cmj 1 3,854 10-14-2024, 05:35 PM
  Yet another new Pinebook keyboard problem MikoBob 3 5,810 09-11-2024, 07:05 AM
Last Post: MikoBob
  Lithium Battery Connector Franestra 0 3,358 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 5,000 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 5,064 02-17-2024, 07:06 PM
