SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating
SOLVED: short solution - it was the connection to the screen and a problem with the board that connection is on. It needed pressure in a specific spot to display, taped a piece of eraser there.
Hi, I just received my pinetab2 today but when I turned it on the screen turns on, but it's just black.
I have tried to flash another image onto it, but that doesn't seem to work for me as it still wont display
on the built in screen.
If I load minicom, I can access the system and login from the terminal, and I can navigate the file system, so
it is actually there, it just wont display on the actual tablet so i can use it for whatever reason.
I tried looking around the forum, and it seems like a lot of other people have (maybe?) similar problems.
I'm sorry for the wall of text but I saw others put their minicom output here, so thats what i'll do too.
I would really appreciate it if someone could help.
Here's the boot., and dmesg is below.
Welcome to minicom 2.8 OPTIONS: I18n Port /dev/ttyUSB0, 23:19:15 Press CTRL-A Z for help on special keys DDR Version V1.13 20220218 ln ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=8192MB tdqss: cs0 dqs0: -24ps, dqs1: -96ps, dqs2: -72ps, dqs3: -217ps, tdqss: cs1 dqs0: -24ps, dqs1: -96ps, dqs2: -72ps, dqs3: -192ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x64 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 1056MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x43 cs 0: the read training result: DQS0:0x3b, DQS1:0x3d, DQS2:0x3f, DQS3:0x35, min  : 0xd  0xd  0xf  0xd  0x2  0x5  0x9  0x5 , 0x9  0x9  0x3  0x2  0xd  0xb  0xe  0xc ,       0xf 0x10  0xc  0xa  0x5  0x1  0x3  0x6 , 0xa  0x7  0x6  0x2  0xe  0xd  0xa  0xd , mid  :0x2a 0x2b 0x2d 0x2b 0x20 0x23 0x27 0x23 ,0x27 0x28 0x22 0x21 0x2b 0x2a 0x2c 0x29 ,       0x2e 0x2f 0x2b 0x29 0x25 0x21 0x22 0x25 ,0x29 0x26 0x25 0x21 0x2d 0x2c 0x28 0x2c , max  :0x48 0x4a 0x4c 0x49 0x3f 0x41 0x45 0x41 ,0x45 0x47 0x41 0x40 0x4a 0x49 0x4b 0x47 ,       0x4e 0x4f 0x4a 0x49 0x46 0x41 0x42 0x45 ,0x48 0x45 0x44 0x40 0x4c 0x4c 0x47 0x4c , range:0x3b 0x3d 0x3d 0x3c 0x3d 0x3c 0x3c 0x3c ,0x3c 0x3e 0x3e 0x3e 0x3d 0x3e 0x3d 0x3b ,       0x3f 0x3f 0x3e 0x3f 0x41 0x40 0x3f 0x3f ,0x3e 0x3e 0x3e 0x3e 0x3e 0x3f 0x3d 0x3f , the write training result: DQS0:0x40, DQS1:0x37, DQS2:0x3a, DQS3:0x26, min  :0x66 0x68 0x6a 0x67 0x5c 0x60 0x64 0x62 0x62 ,0x58 0x58 0x55 0x53 0x5d 0x5b 0x5d 0x5b 0x58 ,       0x63 0x63 0x60 0x5f 0x5a 0x57 0x58 0x5e 0x5e ,0x52 0x50 0x50 0x4d 0x56 0x56 0x52 0x58 0x50 , mid  :0x81 0x83 0x85 0x81 0x77 0x7a 0x7e 0x7c 0x7c ,0x74 0x73 0x6f 0x6f 0x79 0x76 0x77 0x76 0x74 ,       0x7f 0x7f 0x7b 0x7b 0x76 0x72 0x73 0x79 0x7a ,0x6e 0x6b 0x6c 0x69 0x72 0x72 0x6e 0x73 0x6c , max  :0x9c 0x9e 0xa0 0x9c 0x93 0x95 0x99 0x96 0x96 ,0x91 0x8f 0x8a 0x8b 0x95 0x92 0x92 0x91 0x90 ,       0x9c 0x9c 0x97 0x97 0x92 0x8d 0x8f 0x94 x0x96 ,0x8b 0x87 0x88 0x85 0x8f 0x8f 0x8a 0x8f 0x89 , range:0x3:6 0x36 0x36 0x35 0x37 0x35 0x35 0x34 0x34 ,0x39 0x37 0x35 0x38 0x38 0x37 0x35 0x36 0x38 ,       0x39 0x39 0x37 0x38 0x38 0x36 0x37 0x36 0x38 ,0x39 0x37 0x38 0x38 0x39 0x39 0x38 0x37 0x39 , cs 1: the read training result: DQS0:0x39, DQS1:0x3d, DQS2:0x3f, DQS3:0x35, min  : 0xc  0xc  0xf  0xc  0x1  0x4  0x8  0x4 , 0x9  0x9  0x4  0x1  0xd  0xc  0xe  0xc ,       0x10  0xf  0xa  0x9  0x6  0x1  0x4  0x7 , 0xa  0x6  0x6  0x2  0xe  0xd  0xa  0xe , mid  :0x29 0x2a 0x2c 0x29 0x1f 0x22 0x25 0x21 ,0x27 0x28 0x22 0x20 0x2b 0x2a 0x2b 0x29 ,       0x2f 0x2f 0x2a 0x29 0x26 0x20 0x23 0x26 ,0x29 0x25 0x25 0x21 0x2d 0x2c 0x28 0x2d , max  :0x47 0x48 0x4a 0x47 0x3e 0x40 0x43 0x3f ,0x45 0x47 0x41 0x3f 0x49 0x48 0x49 0x47 ,       0x4e 0x4f 0x4a 0x49 0x46 0x40 0x43 0x46 ,0x48 0x45 0x44 0x40 0x4c 0x4c 0x47 0x4c , range:0x3b 0x3c 0x3b 0x3b 0x3d 0x3c 0x3b 0x3b ,0x3c 0x3e 0x3d 0x3e 0x3c 0x3c 0x3b 0x3b ,       0x3e 0x40 0x40 0x40 0x40 0x3f 0x3f 0x3f ,0x3e 0x3f 0x3e 0x3e 0x3e 0x3f 0x3d 0x3e , the write training result: DQS0:0x40, DQS1:0x37, DQS2:0x3a, DQS3:0x26, min  :0x67 0x6a 0x6b 0x69 0x5e 0x62 0x66 0x64 0x65 ,0x5a 0x5a 0x55 0x55 0x5e 0x5c 0x5e 0x5c 0x5a ,       0x65 0x65 0x60 0x60 0x5b 0x58 0x59 0x5e 0x5e ,0x55 0x54 0x53 0x51 0x59 0x59 0x56 0x5b 0x55 , mid  :0x82 0x85 0x86 0x84 0x79 0x7c 0x80 0x7d 0x7e ,0x76 0x75 0x70 0x70 0x79 0x77 0x78 0x77 0x75 ,       0x81 0x81 0x7c 0x7c 0x77 0x73 0x74 0x79 0x7a ,0x72 0x70 0x6f 0x6d 0x76 0x76 0x72 0x77 0x71 , max  :0x9e 0xa0 0xa2 0x9f 0x94 0x96 0x9a 0x97 0x98 ,0x92 0x91 0x8c 0x8b 0x95 0x93 0x93 0x92 0x91 ,       0x9d 0x9e 0x98 0x98 0x94 0x8e 0x90 0x94 0x97 ,0x8f 0x8c 0x8b 0x8a 0x93 0x93 0x8f 0x94 0x8d , range:0x37 0x36 0x37 0x36 0x36 0x34 0x34 0x33 0x33 ,0x38 0x37 0x37 0x36 0x37 0x37 0x35 0x36 0x37 ,       0x38 0x39 0x38 0x38 0x39 0x36 0x37 0x36 0x39 ,0x3a 0x38 0x38 0x39 0x3a 0x3a 0x39 0x39 0x38 , CA Training result: cs:0 min  :0x46 0x3b 0x3b 0x2c 0x3b 0x2d 0x3b ,0x44 0x36 0x38 0x2b 0x3b 0x2b 0x3c , cs:0 mid  :0x7e 0x7f 0x74 0x72 0x74 0x72 0x68 ,0x7c 0x7b 0x70 0x70 0x73 0x70 0x6a , cs:0 max  :0xb6 0xc4 0xae 0xb8 0xae 0xb8 0x96 ,0xb5 0xc1 0xa9 0xb5 0xab 0xb6 0x98 , cs:0 range:0x70 0x89 0x73 0x8c 0x73 0x8b 0x5b ,0x71 0x8b 0x71 0x8a 0x70 0x8b 0x5c , cs:1 min  :0x3f 0x3b 0x36 0x2f 0x36 0x2f 0x36 ,0x40 0x39 0x33 0x2e 0x35 0x2f 0x36 , cs:1 mid  :0x7b 0x7c 0x73 0x71 0x72 0x72 0x66 ,0x7c 0x7b 0x70 0x6f 0x71 0x70 0x67 , cs:1 max  :0xb8 0xbe 0xb0 0xb4 0xaf 0xb5 0x96 ,0xb8 0xbe 0xad 0xb0 0xae 0xb2 0x99 , cs:1 range:0x79 0x83 0x7a 0x85 0x79 0x86 0x60 ,0x78 0x85 0x7a 0x82 0x79 0x83 0x63 , out U-Boot SPL board init U-Boot SPL 2017.09-2-g216faafc18-220629 #builduser (May 25 2023 - 11:00:15) set_freq=96000000Hz fail, check if it's the cru support level Cannot set speed (err=-2) unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 Card did not respond to voltage select! mmc_init: -95, time 10 spl: mmc init failed with error: -95 Trying to boot from MMC1 No misc partition spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(6204b6f381...) + OK ## Checking uboot 0x00a00000 ... sha256(c11ad22269...) + OK ## Checking fdt 0x00b206b0 ... sha256(dd16d48c74...) + OK ## Checking atf-2 0xfdcc1000 ... sha256(5563d929da...) + OK ## Checking atf-3 0x0006a000 ... sha256(b04372ab0f...) + OK ## Checking atf-4 0xfdcd0000 ... sha256(b46eaa95b8...) + OK ## Checking atf-5 0xfdcce000 ... sha256(2f8839c803...) + OK ## Checking atf-6 0x00068000 ... sha256(6e9d32ba23...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 169.868 ms INFO:    Preloader serial: 2 NOTICE:  BL31: v2.3():v2.3-365-gae7c295ca:derrick.huang NOTICE:  BL31: Built : 15:37:13, May 17 2022 INFO:    GICv3 without legacy support detected. INFO:    ARM GICv3 driver initialized in EL3 INFO:    pmu v1 is valid 220114 INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 0 INFO:    BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR:  Error initializing runtime service opteed_fast INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0xa00000 INFO:    SPSR = 0x3c9 U-Boot 2017.09-2-g216faafc18-220629 #builduser (May 25 2023 - 11:00:15 +0000) Model: Pine64 PineTab2 v2.0 PreSerial: 2, raw, 0xfe660000 DRAM:  7.7 GiB Sysmem: init Relocation Offset: ed358000 Relocation fdt: eb9f9380 - eb9fecd0 CR: M/C/I dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 0 MMC0: HS200, 200Mhz PartType: EFI DM: v1 No misc partition boot mode: None No resource partition No resource partition Failed to load DTB, ret=-19 No find valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 io-domain: OK Card did not respond to voltage select! mmc_init: -95, time 10 ** Bad device mmc 1 ** Using default environment In:    serial Out:  serial Err:  serial Model: Pine64 PineTab2 v2.0 rockchip_set_serialno: could not find efuse/otp device CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)   apll 816000 KHz   dpll 528000 KHz   gpll 1188000 KHz   cpll 1000000 KHz   npll 24000 KHz   vpll 24000 KHz   hpll 24000 KHz   ppll 200000 KHz   armclk 816000 KHz   aclk_bus 150000 KHz   pclk_bus 50000 KHz   aclk_top_high 300000 KHz   aclk_top_low 200000 KHz   hclk_top 150000 KHz   pclk_top 50000 KHz   aclk_perimid 300000 KHz   hclk_perimid 150000 KHz   pclk_pmu 100000 KHz No misc partition Net:  No ethernet found. Hit key to stop autoboot('CTRL+C'):  0 Card did not respond to voltage select! mmc_init: -95, time 10 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot.scr reading /boot.scr 940 bytes read in 0 ms ## Executing script at 00c00000 Booting from eMMC Loading kernel... reading /Image.gz 8482543 bytes read in 61 ms (132.6 MiB/s) Uncompressing kernel... Uncompressed size: 20484104 = 0x1389008 Loading initramfs... reading /initramfs-linux.img 8104609 bytes read in 53 ms (145.8 MiB/s) Loading dtb... reading /dtbs/rockchip/rk3566-pinetab2-v2.0.dtb 119800 bytes read in 3 ms (38.1 MiB/s) Booting... Fdt Ramdisk skip relocation No misc partition ## Flattened Device Tree blob at 0x0a100000   Booting using the fdt blob at 0x0a100000   Using Device Tree in place at 000000000a100000, end 000000000a1203f7 can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) == DO RELOCATE == Kernel from 0x00280000 to 0x00400000 Total: 860.891 ms Starting kernel ... [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 [    0.699614] dw-mipi-dsi-rockchip fe060000.dsi: Failed to create device link (0x180) with vcc_3v3 :: running early hook [udev] Starting systemd-udevd version 253.4-1-arch :: running hook [udev] :: Triggering uevents... :: running hook [keymap] :: Loading keymap...kbd_mode: KDSKBMODE: Inappropriate ioctl for device Gdone. :: performing fsck on '/dev/mmcblk1p2' /dev/mmcblk1p2: recovering journal /dev/mmcblk1p2: clean, 192834/7596960 files, 2032596/30496256 blocks :: mounting '/dev/mmcblk1p2' on real root :: running cleanup hook [udev] Welcome to Arch Linux ARM! [  OK  ] Created slice Slice /system/getty. [  OK  ] Created slice Slice /system/modprobe. [  OK  ] Created slice Slice /system/serial-getty. [  OK  ] Created slice Slice /system/systemd-fsck. [  OK  ] Created slice User and Session Slice. [  OK  ] Started Forward Password R…uests to Wall Directory Watch. [  OK  ] Set up automount Arbitrary…s File System Automount Point. [  OK  ] Reached target Local Integrity Protected Volumes. [  OK  ] Reached target Remote File Systems. [  OK  ] Reached target Slice Units. [  OK  ] Reached target Swaps. 1;-1f[  OK  ] Started Show Plymouth Boot Screen. [  OK  ] Started Forward Password R…s to Plymouth Directory Watch. [  OK  ] Reached target Local Encrypted Volumes. [  OK  ] Created slice Slice /system/udisks2-zram-setup.         Starting Load Kernel Module dm_mod...         Starting Load Kernel Module loop... [  OK  ] Finished Load Kernel Module loop. [  OK  ] Finished Load Kernel Module dm_mod. [  OK  ] Found device /dev/ttyS2. [  OK  ] Found device /dev/disk/by-uuid/0159-FDB0. [  OK  ] Created slice Slice /system/systemd-backlight.         Starting Load/Save Screen …ness of backlight:backlight... [  OK  ] Reached target Hardware activated USB gadget. [  OK  ] Finished Load/Save Screen …htness of backlight:backlight. [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. [    7.801266] ov5648 2-0036: failed to find 168000000 clk rate in endpoint link-frequencies [  OK  ] Finished Load/Save OS Random Seed. [  OK  ] Finished Monitoring of LVM… dmeventd or progress polling. [  OK  ] Reached target Preparation for Local File Systems.         Starting File System Check…/dev/disk/by-uuid/0159-FDB0... [  OK  ] Finished File System Check…n /dev/disk/by-uuid/0159-FDB0.         Mounting /boot... [  OK  ] Mounted /boot. [  OK  ] Reached target Local File Systems.         Starting Tell Plymouth To Write Out Runtime Data...         Starting Create Volatile Files and Directories... [  OK  ] Finished Tell Plymouth To Write Out Runtime Data. [  OK  ] Finished Create Volatile Files and Directories.         Starting Network Time Synchronization...         Starting Record System Boot/Shutdown in UTMP... [  OK  ] Reached target Sound Card. [  OK  ] Finished Record System Boot/Shutdown in UTMP. [  OK  ] Started Network Time Synchronization. [  OK  ] Reached target System Initialization. [  OK  ] Started CUPS Scheduler. [  OK  ] Started Daily Cleanup of Temporary Directories. [  OK  ] Reached target Path Units. [  OK  ] Reached target System Time Set. [  OK  ] Started Refresh existing P…f archlinux-keyring regularly. [  OK  ] Started Daily verification of password and group files. [  OK  ] Reached target Timer Units. [  OK  ] Listening on CUPS Scheduler. [  OK  ] Listening on D-Bus System Message Bus Socket. [  OK  ] Reached target Socket Units. [  OK  ] Reached target Basic System.         Starting D-Bus System Message Bus...         Starting User Login Management...         Starting UDisks2 managed ZRAM device zram0 setup...         Starting Zram-based swap (…mpressed RAM block devices)... [  OK  ] Finished UDisks2 managed ZRAM device zram0 setup. [  OK  ] Finished Zram-based swap (compressed RAM block devices). [  OK  ] Started D-Bus System Message Bus.         Starting Network Manager... [  OK  ] Started User Login Management. [  OK  ] Started Network Manager. [  OK  ] Reached target Network.         Starting CUPS Scheduler...         Starting Permit User Sessions...         Starting Hostname Service... [  OK  ] Finished Permit User Sessions.         Starting Hold until boot process finishes up...         Starting Terminate Plymouth Boot Screen...
dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [    0.000000] Linux version 6.3.0-2-danctnix (builduser@alarm) (aarch64-unknown-linux-gnu-gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT_DYNAMIC Fri May 26 07:05:36 UTC 2023 [    0.000000] Machine model: Pine64 PineTab2 v2.0 [    0.000000] NUMA: No NUMA configuration found [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff] [    0.000000] NUMA: NODE_DATA [mem 0x1fefdafc0-0x1fefdcfff] [    0.000000] Zone ranges: [    0.000000]  DMA      [mem 0x0000000000200000-0x00000000ffffffff] [    0.000000]  DMA32    empty [    0.000000]  Normal  [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Movable zone start for each node [    0.000000] Early memory node ranges [    0.000000]  node  0: [mem 0x0000000000200000-0x00000000efffffff] [    0.000000]  node  0: [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [    0.000000] cma: Reserved 256 MiB at 0x00000000e0000000 [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.1 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: MIGRATE_INFO_TYPE not supported. [    0.000000] psci: SMC Calling Convention v1.2 [    0.000000] percpu: Embedded 21 pages/cpu s48744 r8192 d29080 u86016 [    0.000000] pcpu-alloc: s48744 r8192 d29080 u86016 alloc=21*4096 [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: detected: GIC system register CPU interface [    0.000000] CPU features: detected: Virtualization Host Extensions [    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [    0.000000] alternatives: applying boot alternatives [    0.000000] Fallback order for Node 0: 0 [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1999368 [    0.000000] Policy zone: Normal [    0.000000] Kernel command line: loglevel=4 root=/dev/mmcblk1p2 rw rootwait [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [    0.000000] software IO TLB: area num 4. [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [    0.000000] Memory: 7611308K/8124416K available (12224K kernel code, 1316K rwdata, 4028K rodata, 2304K init, 442K bss, 250964K reserved, 262144K cma-reserved) [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] Dynamic Preempt: full [    0.000000] rcu: Preemptible hierarchical RCU implementation. [    0.000000] rcu:    RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4. [    0.000000]  Trampoline variant of Tasks RCU enabled. [    0.000000]  Tracing variant of Tasks RCU enabled. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode [    0.000000] GICv3: 320 SPIs implemented [    0.000000] GICv3: 0 Extended SPIs implemented [    0.000000] GICv3: MBI range [296:319] [    0.000000] GICv3: Using MBI frame 0x00000000fd410000 [    0.000000] Root IRQ handler: gic_handle_irq [    0.000000] GICv3: GICv3 features: 16 PPIs [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    0.000000] ITS: No ITS available, not enabling LPIs [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.001973] Console: colour dummy device 80x25 [    0.001993] printk: console [tty0] enabled [    0.002186] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [    0.002208] pid_max: default: 32768 minimum: 301 [    0.002314] LSM: initializing lsm=capability,integrity,apparmor [    0.002470] AppArmor: AppArmor initialized [    0.002627] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [    0.002687] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [    0.005598] cblist_init_generic: Setting adjustable number of callback queues. [    0.005623] cblist_init_generic: Setting shift to 2 and lim to 1. [    0.005803] cblist_init_generic: Setting shift to 2 and lim to 1. [    0.006162] rcu: Hierarchical SRCU implementation. [    0.006173] rcu:    Max phase no-delay instances is 1000. [    0.007690] smp: Bringing up secondary CPUs ... [    0.008699] Detected VIPT I-cache on CPU1 [    0.008784] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    0.008844] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    0.009949] Detected VIPT I-cache on CPU2 [    0.010021] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    0.010064] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    0.011142] Detected VIPT I-cache on CPU3 [    0.011208] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [    0.011247] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [    0.011386] smp: Brought up 1 node, 4 CPUs [    0.011410] SMP: Total of 4 processors activated. [    0.011420] CPU features: detected: 32-bit EL0 Support [    0.011426] CPU features: detected: 32-bit EL1 Support [    0.011433] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [    0.011440] CPU features: detected: Common not Private translations [    0.011446] CPU features: detected: CRC32 instructions [    0.011454] CPU features: detected: RCpc load-acquire (LDAPR) [    0.011460] CPU features: detected: LSE atomic instructions [    0.011467] CPU features: detected: Privileged Access Never [    0.011472] CPU features: detected: RAS Extension Support [    0.011480] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [    0.011680] CPU: All CPU(s) started at EL2 [    0.011690] alternatives: applying system-wide alternatives [    0.018703] devtmpfs: initialized [    0.043022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [    0.043067] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [    0.050513] pinctrl core: initialized pinctrl subsystem [    0.052074] NET: Registered PF_NETLINK/PF_ROUTE protocol family [    0.053562] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [    0.053860] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [    0.054322] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [    0.054394] audit: initializing netlink subsys (disabled) [    0.054668] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1 [    0.055859] thermal_sys: Registered thermal governor 'fair_share' [    0.055873] thermal_sys: Registered thermal governor 'step_wise' [    0.055881] thermal_sys: Registered thermal governor 'user_space' [    0.055887] thermal_sys: Registered thermal governor 'power_allocator' [    0.056011] cpuidle: using governor ladder [    0.056055] cpuidle: using governor menu [    0.056225] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.056403] ASID allocator initialised with 65536 entries [    0.056586] Serial: AMBA PL011 UART driver [    0.070402] platform fe060000.dsi: Fixed dependency cycle(s) with /dsi@fe060000/panel@0/ports/port@0/endpoint@0 [    0.070459] platform fe060000.dsi: Fixed dependency cycle(s) with /vop@fe040000/ports/port@1/endpoint@4 [    0.071201] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000/ports/port@0/endpoint@2 [    0.101208] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [    0.101769] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [    0.102289] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [    0.102640] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [    0.103026] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [    0.103363] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [    0.103820] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [    0.104153] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [    0.104661] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [    0.104987] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [    0.108961] platform hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000/ports/port@1/endpoint [    0.117073] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [    0.117097] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [    0.117108] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [    0.117114] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [    0.117123] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [    0.117130] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [    0.117137] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [    0.117143] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [    0.118549] cryptd: max_cpu_qlen set to 1000 [    0.119758] fbcon: Taking over console [    0.121840] iommu: Default domain type: Translated [    0.121857] iommu: DMA domain TLB invalidation policy: strict mode [    0.122222] SCSI subsystem initialized [    0.122550] usbcore: registered new interface driver usbfs [    0.122604] usbcore: registered new interface driver hub [    0.122657] usbcore: registered new device driver usb [    0.123503] mc: Linux media interface: v0.10 [    0.123585] videodev: Linux video capture interface: v2.00 [    0.123985] EDAC MC: Ver: 3.0.0 [    0.124877] scmi_core: SCMI protocol bus registered [    0.126830] clocksource: Switched to clocksource arch_sys_counter [    0.127161] VFS: Disk quotas dquot_6.6.0 [    0.127215] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    0.127955] AppArmor: AppArmor Filesystem Enabled [    0.141328] NET: Registered PF_INET protocol family [    0.142128] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [    0.150085] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [    0.150177] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [    0.150207] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [    0.150767] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [    0.153026] TCP: Hash tables configured (established 65536 bind 65536) [    0.153231] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [    0.153396] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [    0.153822] NET: Registered PF_UNIX/PF_LOCAL protocol family [    0.154384] Unpacking initramfs... [    0.155360] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [    0.157154] kvm [1]: IPA Size Limit: 40 bits [    0.157196] kvm [1]: GICv3: no GICV resource entry [    0.157206] kvm [1]: disabling GICv2 emulation [    0.157234] kvm [1]: GIC system register CPU interface enabled [    0.157271] kvm [1]: vgic interrupt IRQ9 [    0.157324] kvm [1]: VHE mode initialized successfully [    0.161975] Initialise system trusted keyrings [    0.162301] workingset: timestamp_bits=44 max_order=21 bucket_order=0 [    0.214638] NET: Registered PF_ALG protocol family [    0.214695] Key type asymmetric registered [    0.214705] Asymmetric key parser 'x509' registered [    0.215149] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [    0.215228] io scheduler mq-deadline registered [    0.215240] io scheduler kyber registered [    0.253782] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330 [    0.253815] dma-pl330 fe530000.dma-controller:      DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    0.261999] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330 [    0.262030] dma-pl330 fe550000.dma-controller:      DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    0.277782] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [    0.284679] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 29, base_baud = 1500000) is a 16550A [    0.287552] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 30, base_baud = 1500000) is a 16550A [    0.287885] printk: console [ttyS2] enabled [    0.298734] rockchip-vop2 fe040000.vop: Adding to iommu group 2 [    0.327937] loop: module loaded [    0.329305] zram: Added device: zram0 [    0.335384] tun: Universal TUN/TAP device driver, 1.6 [    0.336637] VFIO - User Level meta-driver version: 0.3 [    0.343473] usbcore: registered new interface driver cdc_acm [    0.343503] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [    0.343727] usbcore: registered new interface driver usb-storage [    0.344188] usbcore: registered new interface driver usbserial_generic [    0.344387] usbserial: USB Serial support registered for generic [    0.353687] i2c_dev: i2c /dev entries driver [    0.357024] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [    0.359402] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/regulators/BOOST [    0.361281] rk808 0-0020: chip id: 0x8170 [    0.378209] rk808-regulator rk808-regulator.1.auto: there is no dvs0 gpio [    0.378258] rk808-regulator rk808-regulator.1.auto: there is no dvs1 gpio [    0.390604] vccio_acodec: Bringing 600000uV into 3300000-3300000uV [    0.399096] vcc1v8_dvp: Bringing 600000uV into 1800000-1800000uV [    0.401732] vcc2v8_dvp: Bringing 600000uV into 2800000-2800000uV [    0.404385] boost: Bringing 4700000uV into 5000000-5000000uV [    0.414351] rk808-rtc rk808-rtc.3.auto: registered as rtc0 [    0.415281] rk808-rtc rk808-rtc.3.auto: setting system clock to 2023-09-03T00:01:50 UTC (1693699310) [    0.523424] Goodix-TS 1-005d: ID 911, version: 1060 [    0.555596] device-mapper: uevent: version 1.0.3 [    0.555978] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com [    0.559614] sdhci: Secure Digital Host Controller Interface driver [    0.559639] sdhci: Copyright(c) Pierre Ossman [    0.559646] Synopsys Designware Multimedia Card Interface Driver [    0.562072] sdhci-pltfm: SDHCI platform and OF driver helper [    0.566150] ledtrig-cpu: registered to indicate activity on CPUs [    0.567601] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [    0.568067] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [    0.568168] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [    0.571393] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [    0.571785] hid: raw HID events driver (C) Jiri Kosina [    0.575735] usbcore: registered new interface driver usbhid [    0.575763] usbhid: USB HID core driver [    0.585429] Initializing XFRM netlink socket [    0.585500] NET: Registered PF_PACKET protocol family [    0.585816] Key type dns_resolver registered [    0.593686] Freeing initrd memory: 7912K [    0.598616] Goodix-TS 1-005d: Direct firmware load for goodix_911_cfg.bin failed with error -2 [    0.603999] input: Goodix Capacitive TouchScreen as /devices/platform/fe5a0000.i2c/i2c-1/1-005d/input/input0 [    0.642306] registered taskstats version 1 [    0.642698] Loading compiled-in X.509 certificates [    0.657498] Key type .fscrypt registered [    0.657525] Key type fscrypt-provisioning registered [    0.657727] AppArmor: AppArmor sha1 policy hashing enabled [    0.699614] dw-mipi-dsi-rockchip fe060000.dsi: Failed to create device link (0x180) with vcc_3v3 [    0.701857] vcc3v3_sd enforce active low on GPIO handle [    0.719506] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops) [    0.720844] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [    0.721776] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [    0.722545] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops) [    0.723358] rockchip-drm display-subsystem: bound fe060000.dsi (ops dw_mipi_dsi_rockchip_ops) [    0.724768] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [    0.724939] ------------[ cut here ]------------ [    0.724954] WARNING: CPU: 1 PID: 50 at drivers/gpu/drm/drm_mode_object.c:45 drm_mode_object_add+0x90/0x98 [    0.724991] Modules linked in: [    0.725009] CPU: 1 PID: 50 Comm: kworker/u8:1 Not tainted 6.3.0-2-danctnix #1 [    0.725024] Hardware name: Pine64 PineTab2 v2.0 (DT) [    0.725034] Workqueue: events_unbound deferred_probe_work_func [    0.725058] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [    0.725071] pc : drm_mode_object_add+0x90/0x98 [    0.725086] lr : drm_property_create+0xd0/0x188 [    0.725102] sp : ffff8000099f35b0 [    0.725109] x29: ffff8000099f35b0 x28: ffff000103cdd780 x27: 0000000000000037 [    0.725133] x26: 0000000000001000 x25: 0000000000001000 x24: ffff000102385800 [    0.725155] x23: ffff800008f160c0 x22: 0000000000000004 x21: 00000000b0b0b0b0 [    0.725176] x20: ffff000103f02c90 x19: ffff000102385800 x18: ffff8000099dd110 [    0.725198] x17: 206d657473797362 x16: 75732d79616c7073 x15: ffff8000099f3550 [    0.725219] x14: ffff000103f02ff0 x13: ffff000103f02fd4 x12: 0000000000000000 [    0.725240] x11: 0000000000000001 x10: 0000000000000078 x9 : 0000000000000000 [    0.725260] x8 : ffff000103f02d80 x7 : 0000000000000000 x6 : 000000000000003f [    0.725280] x5 : 0000000000000040 x4 : ffff8000099f35c0 x3 : 0000000000000000 [    0.725301] x2 : 00000000b0b0b0b0 x1 : ffff000103f02c90 x0 : 0000000000000001 [    0.725321] Call trace: [    0.725329]  drm_mode_object_add+0x90/0x98 [    0.725345]  drm_property_create+0xd0/0x188 [    0.725358]  drm_property_create_enum+0x30/0x94 [    0.725370]  drm_connector_set_panel_orientation+0x94/0xb4 [    0.725386]  boe_get_modes+0x70/0xbc [    0.725402]  drm_panel_get_modes+0x28/0x48 [    0.725417]  panel_bridge_connector_get_modes+0x1c/0x2c [    0.725432]  drm_helper_probe_single_connector_modes+0x1a4/0x52c [    0.725444]  drm_client_modeset_probe+0x204/0x1194 [    0.725458]  __drm_fb_helper_initial_config_and_unlock+0x54/0x494 [    0.725472]  drm_fb_helper_initial_config+0x4c/0x60 [    0.725485]  drm_fbdev_client_hotplug+0x8c/0xd8 [    0.725498]  drm_fbdev_generic_setup+0x90/0x170 [    0.725511]  rockchip_drm_bind+0x1ec/0x208 [    0.725528]  try_to_bring_up_aggregate_device+0x170/0x1c0 [    0.725547]  __component_add+0xa8/0x174 [    0.725561]  component_add+0x18/0x28 [    0.725576]  dw_mipi_dsi_rockchip_host_attach+0x5c/0x14c [    0.725589]  dw_mipi_dsi_host_attach+0x98/0xcc [    0.725603]  mipi_dsi_attach+0x2c/0x44 [    0.725616]  boe_dsi_probe+0xf8/0x1a0 [    0.725628]  mipi_dsi_drv_probe+0x24/0x34 [    0.725641]  really_probe+0x150/0x2b4 [    0.725656]  __driver_probe_device+0x7c/0xe8 [    0.725670]  driver_probe_device+0x40/0x164 [    0.725684]  __device_attach_driver+0xc4/0x144 [    0.725699]  bus_for_each_drv+0x88/0xe8 [    0.725713]  __device_attach+0xa0/0x190 [    0.725727]  device_initial_probe+0x18/0x28 [    0.725741]  bus_probe_device+0xb0/0xb4 [    0.725755]  deferred_probe_work_func+0x88/0xc4 [    0.725769]  process_one_work+0x1dc/0x340 [    0.725787]  worker_thread+0x224/0x434 [    0.725800]  kthread+0x10c/0x110 [    0.725813]  ret_from_fork+0x10/0x20 [    0.725829] ---[ end trace 0000000000000000 ]--- [    0.726035] ------------[ cut here ]------------ [    0.726047] WARNING: CPU: 1 PID: 50 at drivers/gpu/drm/drm_mode_object.c:242 drm_object_attach_property+0x6c/0xb8 [    0.726077] Modules linked in: [    0.726091] CPU: 1 PID: 50 Comm: kworker/u8:1 Tainted: G        W          6.3.0-2-danctnix #1 [    0.726105] Hardware name: Pine64 PineTab2 v2.0 (DT) [    0.726114] Workqueue: events_unbound deferred_probe_work_func [    0.726135] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [    0.726147] pc : drm_object_attach_property+0x6c/0xb8 [    0.726162] lr : drm_connector_set_panel_orientation+0x68/0xb4 [    0.726176] sp : ffff8000099f3650 [    0.726182] x29: ffff8000099f3650 x28: ffff000103cdd780 x27: 0000000000000037 [    0.726205] x26: 0000000000001000 x25: 0000000000001000 x24: ffff000102385800 [    0.726227] x23: 00000000fffffffd x22: ffff000101a45380 x21: ffff000102385800 [    0.726248] x20: ffff000102385238 x19: ffff000102385170 x18: ffff8000099dd0f8 [    0.726269] x17: 206d657473797362 x16: 75732d79616c7073 x15: ffff8000099f3550 [    0.726290] x14: ffff000103f02ff0 x13: ffff000103f02fd4 x12: 0000000000000000 [    0.726311] x11: 0000000000000001 x10: 0000000000000078 x9 : 0000000000000000 [    0.726331] x8 : ffff000103f02838 x7 : 00000000c0c0c0c0 x6 : 00000000c0c0c0c0 [    0.726352] x5 : 0000000000000000 x4 : 0000000000000001 x3 : 0000000000000006 [    0.726371] x2 : 0000000000000003 x1 : ffff000103f02c80 x0 : ffff0001023851b0 [    0.726394] Call trace: [    0.726400]  drm_object_attach_property+0x6c/0xb8 [    0.726415]  boe_get_modes+0x70/0xbc [    0.726430]  drm_panel_get_modes+0x28/0x48 [    0.726446]  panel_bridge_connector_get_modes+0x1c/0x2c [    0.726460]  drm_helper_probe_single_connector_modes+0x1a4/0x52c [    0.726473]  drm_client_modeset_probe+0x204/0x1194 [    0.726486]  __drm_fb_helper_initial_config_and_unlock+0x54/0x494 [    0.726500]  drm_fb_helper_initial_config+0x4c/0x60 [    0.726514]  drm_fbdev_client_hotplug+0x8c/0xd8 [    0.726526]  drm_fbdev_generic_setup+0x90/0x170 [    0.726538]  rockchip_drm_bind+0x1ec/0x208 [    0.726555]  try_to_bring_up_aggregate_device+0x170/0x1c0 [    0.726573]  __component_add+0xa8/0x174 [    0.726589]  component_add+0x18/0x28 [    0.726604]  dw_mipi_dsi_rockchip_host_attach+0x5c/0x14c [    0.726618]  dw_mipi_dsi_host_attach+0x98/0xcc [    0.726630]  mipi_dsi_attach+0x2c/0x44 [    0.726643]  boe_dsi_probe+0xf8/0x1a0 [    0.726655]  mipi_dsi_drv_probe+0x24/0x34 [    0.726668]  really_probe+0x150/0x2b4 [    0.726682]  __driver_probe_device+0x7c/0xe8 [    0.726696]  driver_probe_device+0x40/0x164 [    0.726709]  __device_attach_driver+0xc4/0x144 [    0.726724]  bus_for_each_drv+0x88/0xe8 [    0.726738]  __device_attach+0xa0/0x190 [    0.726751]  device_initial_probe+0x18/0x28 [    0.726764]  bus_probe_device+0xb0/0xb4 [    0.726776]  deferred_probe_work_func+0x88/0xc4 [    0.726789]  process_one_work+0x1dc/0x340 [    0.726805]  worker_thread+0x224/0x434 [    0.726817]  kthread+0x10c/0x110 [    0.726829]  ret_from_fork+0x10/0x20 [    0.726843] ---[ end trace 0000000000000000 ]--- [    1.448407] Console: switching to colour frame buffer device 160x50 [    1.475788] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [    1.477241] panfrost fde60000.gpu: clock rate = 594000000 [    1.477293] panfrost fde60000.gpu: bus_clock rate = 500000000 [    1.480015] panfrost fde60000.gpu: [drm:panfrost_devfreq_init] Failed to register cooling device [    1.480129] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0 [    1.480148] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400 [    1.480162] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7 [    1.480178] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1 [    1.483450] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 1 [    1.495326] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [    1.495386] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 1 [    1.495569] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [    1.495666] xhci-hcd xhci-hcd.9.auto: irq 72, io mem 0xfd000000 [    1.495887] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [    1.495912] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 2 [    1.495935] xhci-hcd xhci-hcd.9.auto: Host supports USB 3.0 SuperSpeed [    1.497340] hub 1-0:1.0: USB hub found [    1.497411] hub 1-0:1.0: 1 port detected [    1.498300] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [    1.499703] hub 2-0:1.0: USB hub found [    1.499775] hub 2-0:1.0: 1 port detected [    1.503765] input: adc-keys as /devices/platform/adc-keys/input/input2 [    1.504443] ehci-platform fd800000.usb: EHCI Host Controller [    1.504478] ohci-platform fd840000.usb: Generic Platform OHCI controller [    1.504501] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3 [    1.504521] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 4 [    1.504680] ehci-platform fd800000.usb: irq 73, io mem 0xfd800000 [    1.504703] ohci-platform fd840000.usb: irq 74, io mem 0xfd840000 [    1.510805] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [    1.510930] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [    1.510947] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [    1.511037] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 75,32 bit host data width,256 deep fifo [    1.512134] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO [    1.514417] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [    1.514519] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [    1.514536] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [    1.514634] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 76,32 bit host data width,256 deep fifo [    1.516013] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq [    1.516052] mmc_host mmc2: card is non-removable. [    1.517437] input: gpio-keys as /devices/platform/gpio-keys/input/input3 [    1.518909] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [    1.520275] hub 3-0:1.0: USB hub found [    1.520378] hub 3-0:1.0: 1 port detected [    1.521569] dw-apb-uart fe660000.serial: forbid DMA for kernel console [    1.522943] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [    1.542865] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [    1.568002] hub 4-0:1.0: USB hub found [    1.568079] hub 4-0:1.0: 1 port detected [    1.620294] mmc1: new HS200 MMC card at address 0001 [    1.621588] mmcblk1: mmc1:0001 SPeMMC 116 GiB [    1.627264]  mmcblk1: p1 p2 [    1.628762] mmcblk1boot0: mmc1:0001 SPeMMC 4.00 MiB [    1.631646] mmcblk1boot1: mmc1:0001 SPeMMC 4.00 MiB [    1.633979] mmcblk1rpmb: mmc1:0001 SPeMMC 4.00 MiB, chardev (244:0) [    1.735043] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [    1.750230] Freeing unused kernel memory: 2304K [    1.763034] Run /init as init process [    1.763063]  with arguments: [    1.763075]    /init [    1.763088]  with environment: [    1.763098]    HOME=/ [    1.763108]    TERM=linux [    1.986919] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) [    2.110931] usb 4-1: new full-speed USB device number 2 using ohci-platform [    2.361091] input: HID 1018:1006 as /devices/platform/fd840000.usb/usb4/4-1/4-1:1.0/0003:1018:1006.0001/input/input4 [    2.419685] hid-generic 0003:1018:1006.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 1018:1006] on usb-fd840000.usb-1/input0 [    2.462495] input: HID 1018:1006 Mouse as /devices/platform/fd840000.usb/usb4/4-1/4-1:1.1/0003:1018:1006.0002/input/input5 [    2.462979] input: HID 1018:1006 Touchpad as /devices/platform/fd840000.usb/usb4/4-1/4-1:1.1/0003:1018:1006.0002/input/input6 [    2.463337] input: HID 1018:1006 System Control as /devices/platform/fd840000.usb/usb4/4-1/4-1:1.1/0003:1018:1006.0002/input/input7 [    2.523404] input: HID 1018:1006 Consumer Control as /devices/platform/fd840000.usb/usb4/4-1/4-1:1.1/0003:1018:1006.0002/input/input8 [    2.524829] hid-multitouch 0003:1018:1006.0002: input,hidraw1: USB HID v1.11 Mouse [HID 1018:1006] on usb-fd840000.usb-1/input1 [    2.906600] EXT4-fs (mmcblk1p2): mounted filesystem fd81b132-4bd6-40ff-8dfd-a31528d2d405 with ordered data mode. Quota mode: none. [    3.904587] NET: Registered PF_INET6 protocol family [    3.905522] Segment Routing with IPv6 [    3.905559] In-situ OAM (IOAM) with IPv6 [    4.002745] systemd[1]: systemd 253.4-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE) [    4.002797] systemd[1]: Detected architecture arm64. [    4.015476] systemd[1]: Hostname set to <danctnix>. [    4.221400] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported [    4.222961] memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd' [    4.870964] systemd[1]: Queued start job for default target Graphical Interface. [    4.894448] systemd[1]: Created slice Slice /system/getty. [    4.908522] systemd[1]: Created slice Slice /system/modprobe. [    4.920361] systemd[1]: Created slice Slice /system/serial-getty. [    4.932634] systemd[1]: Created slice Slice /system/systemd-fsck. [    4.944057] systemd[1]: Created slice User and Session Slice. [    4.955656] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [    4.967769] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [    4.979243] systemd[1]: Reached target Local Integrity Protected Volumes. [    4.991224] systemd[1]: Reached target Remote File Systems. [    5.003045] systemd[1]: Reached target Slice Units. [    5.015052] systemd[1]: Reached target Swaps. [    5.027260] systemd[1]: Reached target Local Verity Protected Volumes. [    5.039776] systemd[1]: Listening on Device-mapper event daemon FIFOs. [    5.052560] systemd[1]: Listening on LVM2 poll daemon socket. [    5.074196] systemd[1]: Listening on Process Core Dump Socket. [    5.088709] systemd[1]: Listening on Journal Socket (/dev/log). [    5.100556] systemd[1]: Listening on Journal Socket. [    5.115933] systemd[1]: Listening on udev Control Socket. [    5.119061] systemd[1]: Listening on udev Kernel Socket. [    5.147668] systemd[1]: Mounting Huge Pages File System... [    5.159087] systemd[1]: Mounting POSIX Message Queue File System... [    5.173215] systemd[1]: Mounting Kernel Debug File System... [    5.175513] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [    5.185886] systemd[1]: Mounting Temporary Directory /tmp... [    5.197338] systemd[1]: Starting Create List of Static Device Nodes... [    5.206330] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling... [    5.228558] systemd[1]: Starting Load Kernel Module configfs... [    5.240236] systemd[1]: Starting Load Kernel Module dm_mod... [    5.250616] systemd[1]: Starting Load Kernel Module drm... [    5.261214] systemd[1]: Starting Load Kernel Module fuse... [    5.271189] systemd[1]: Starting Load Kernel Module loop... [    5.272843] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [    5.285422] systemd[1]: Starting Journal Service... [    5.298127] systemd[1]: Starting Load Kernel Modules... [    5.315262] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f). [    5.319862] systemd[1]: Starting Remount Root and Kernel File Systems... [    5.347449] systemd[1]: Starting Coldplug All udev Devices... [    5.359823] systemd-journald[2076]: Collecting audit messages is disabled. [    5.366049] EXT4-fs (mmcblk1p2): re-mounted fd81b132-4bd6-40ff-8dfd-a31528d2d405. Quota mode: none. [    5.379104] systemd[1]: Mounted Huge Pages File System. [    5.381416] systemd[1]: Mounted POSIX Message Queue File System. [    5.383604] systemd[1]: Mounted Kernel Debug File System. [    5.385489] systemd[1]: Mounted Temporary Directory /tmp. [    5.388043] systemd[1]: Finished Create List of Static Device Nodes. [    5.391607] systemd[1]: modprobe@configfs.service: Deactivated successfully. [    5.392262] systemd[1]: Finished Load Kernel Module configfs. [    5.396803] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [    5.397538] systemd[1]: Finished Load Kernel Module dm_mod. [    5.401907] systemd[1]: modprobe@drm.service: Deactivated successfully. [    5.402583] systemd[1]: Finished Load Kernel Module drm. [    5.408387] systemd[1]: modprobe@loop.service: Deactivated successfully. [    5.409112] systemd[1]: Finished Load Kernel Module loop. [    5.411970] systemd[1]: Finished Load Kernel Modules. [    5.424350] systemd[1]: Finished Remount Root and Kernel File Systems. [    5.443823] fuse: init (API version 7.38) [    5.455468] systemd[1]: Mounting Kernel Configuration File System... [    5.456482] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes). [    5.460084] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [    5.464212] systemd[1]: Starting Load/Save OS Random Seed... [    5.483217] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met. [    5.487171] systemd[1]: Starting Apply Kernel Variables... [    5.499449] systemd[1]: Create System Users was skipped because no trigger condition checks were met. [    5.503298] systemd[1]: Starting Create Static Device Nodes in /dev... [    5.519051] systemd[1]: Starting Setup Virtual Console... [    5.538665] systemd[1]: Started Journal Service. [    5.668106] systemd-journald[2076]: Received client request to flush runtime journal. [    5.673074] systemd-journald[2076]: File /var/log/journal/81ffa96764264fbc8ce74389a3e9d53d/system.journal corrupted or uncleanly shut down, renaming and replacing. [    7.801266] ov5648 2-0036: failed to find 168000000 clk rate in endpoint link-frequencies [    7.872776] iio iio:device1: interrupts on the falling edge or active low level [    8.082876] random: crng init done [    8.624183] hantro-vpu fdea0000.video-codec: Adding to iommu group 0 [    8.624925] hantro-vpu fdea0000.video-codec: registered rockchip,rk3568-vpu-dec as /dev/video0 [    8.625560] hantro-vpu fdee0000.video-codec: Adding to iommu group 1 [    8.626978] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video1 [    8.722968] input: PineTab Headphones as /devices/platform/rk817-sound/sound/card0/input9 [    9.064218] zram0: detected capacity change from 0 to 6306936 [    9.094024] Adding 3153464k swap on /dev/zram0.  Priority:100 extents:1 across:3153464k SS [  18.911969] platform hdmi-sound: deferred probe pending [  51.348199] systemd-journald[2076]: File /var/log/journal/81ffa96764264fbc8ce74389a3e9d53d/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
I suggest you first update the software to the latest version with "sudo pacman -Syu" and reboot to see if that fixes things.
For next time (or you could edit your post), if you put that 'wall of text' in a "code" block, then it would get scroll bars and be less of a wall of text.
But providing the full logs as you did is more important then the formatting of it :-)
The logs don't indicate anything to worry about, although f.e. u-boot is a 'bit' old and we're also in the 6.4.x kernel series now. Several issues have been found and fixed since the factory 'firmware' you're currently running. Therefor upgrading to the latest versions may be the only fix you need
So i got a USB-C to Ethernet adapter but I can't seem to update, i get an error.
Synchronizing package databases...
danctnix
danctnix.db failed to downloaderror: failed retrieving file 'danctnix.db' from p64.arikawa-hi.me : Could not resolve
host: p64.arikawa-hi.me
warning: too many errors from p64.arikawa-hi.me, skipping for the remainder of this transaction
error: failed to synchronize all databases (invalid url for server)
but i went to that address on my laptop and it's clearly there.
any suggestions?
it was a problem with the connector to the screen.
I pushed it in and it started to work, but it stopped after a while. After more probing I found that I needed to keep pressure in one spot on the little board across the battery from the rest of the stuff (hidden under the strip of tape). My solution to keeping constant pressure there was to cut a small piece of eraser and tape it in place, that way the case will constantly push on it. Probably not the best solution, but seems to be working for now.
Once the screen was working i could flash it and it boots up.
(09-04-2023, 09:36 AM)bacon_dude Wrote: it was a problem with the connector to the screen.
May be due to LCD flex cable, you can file ticket at https://support.pine64.org explain your situation and request for LCD flex cable replacement.
(09-02-2023, 08:49 AM)bacon_dude Wrote: So i got a USB-C to Ethernet adapter but I can't seem to update, i get an error.
... Could not resolve host: p64.arikawa-hi.me
any suggestions?
  1. Try if you can 'ping' your local router, which is often 192.168.1.1.
  2. If that works, ping 1.1.1.1
  3. If that works, ping debian.org
ad 1) If that fails, then your network connection doesn't work at all. My guess is that this is the issue. Look at the arch wiki on how to solve that.
The IP address on your PT2 and your laptop would normally be in the same subnet (192.168.1.x)
ad 2) this is unlikely to be the issue as it works from your laptop, but if it doesn't work then that would indicate an issue between your router and your ISP and via that, the internet
ad 3) If this is the culprit, then you have a DNS issue. Look at /etc/resolv.conf on your laptop and your PT2 and figure out why they are different.
Posting the output of `ip a` may be useful too.
Not Updating Solved.
TLDR: The repository servers shipped with the factory
danctnix image are out of date, preventing system updates.
The referenced repositories were out of date in /etc/pacman.conf
It shipped with Server = https://p64.arikawa-hi.me/$repo/$arch
I changed it to Server = https://archmobile.mirror.danctnix.org/$repo/$arch
after this it started working a little.
after this, [core], [extra], [community], [alarm], and [aur] were set by:
Include = /etc/pacman.d/mirrorlist
In /etc/pacman.d/mirrorlist, the default Geo-IP based mirror
selection and load balancing server was:
Server = http://mirror.archlinuxarm.org/$arch/$repo
This server location was giving me errors and preventing updates as well.
I commented it out and un-commented one of the servers for my country,
in this case the california server in the US.
after this I was able to update the tablet.
  PineTab2 spec for ddr and rth 0 3,259 12-09-2025, 08:28 PM
Last Post: rth
  Pinetab2 not starting Corconegre 12 25,192 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 4,721 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 17,813 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 4,397 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 7,684 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 6,075 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 3,032 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 2,957 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 16,986 09-15-2023, 11:45 PM
Last Post: Ome Ko
