Armbian and LibreELEC and AltLinux for Quartz64
for Quartz64-A , Quartz64-B , SOQuartz + SOQuartz Model-A Baseboard
Libreelec 20230704 kermel 6.4.1 KODI-21
ArmbianTV 20230704 kernel current 6.3.11 and edge 6.4.1
Altlinux 20230704 kernel 6.3.11
It seems like https://users.armbian.com/balbes150/soquartz/ is not a valid link anymore.
Are you able to re-upload it?
all image SOQuartz
https://disk.yandex.ru/d/Oq5yvBkuIK4R3A
ArmbianTV 20230713 kernel current 6.3.13 and edge 6.4.3
Altlinux kernel 6.4.3
Thank you for the excellent work @balbes150 !
Are you still interested in a UART log from a non-UEFI Armbian image on an 8 GB Quartz64 A?
I noticed you've posted about fixing the RAM issue, but I just wanted to check, maybe that only applied to the EDK 2 images.
I installed an EDK 2 image yesterday (slightly older one from May, didn't notice you had images from July until now).
Works like a charm so far, I put Home Assistant Core on it, migrated my old config, and it just works.
(I tried the "official" CSC image on the armbian download page first just to check, and that only reported 2 GB, but also froze hard a few minutes after boot, no heartbeat, no kernel panic AFAICT, just froze.)
Let me know if you want me to test other stuff as well, and I'll see what I can do.
(DIY NAS and router builds in the works, so I have a small pile of noname i210 nics and a SATA 4-port (marvell IIRC) board just waiting to be plugged in.)
(08-01-2023, 07:06 AM)anwe Wrote: Are you still interested in a UART log from a non-UEFI Armbian image on an 8 GB Quartz64 A?
The memory size is fixed for all versions (u-boot and EDK2). It would be interesting to check out the different equipment that you have.
Ok, cool
The Home Assistant build (the only one more or less finished) isn't very interesting hardware-wise, it's just in the small aluminium case with a ConBee II USB stick hanging off it, booting from a 64 GB eMMC.
I can post some lspci output or so from the NICs/SATA cards when I get to the NAS build, but maybe that belongs in a different thread.
(The router is a RockPro64 and runs OpenWRT, so definitely off topic here.)
ArmbianTV 20230905 kernel current 6.4.14 and edge 6.5.1
Libreelec 20230906 kermel 6.4.15
Altlinux kernel 6.4.15
  USB on Quartz64 Zero litbulb 1 2,982 07-22-2026, 02:04 PM
Last Post: MichaIng
  DietPi OS for Quartz64 MichaIng 48 64,388 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,048 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,692 07-30-2025, 07:19 AM
Last Post: pugzarecute
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 94,659 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 6,153 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,948 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,933 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,691 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,367 07-21-2022, 01:08 PM
Last Post: Randomuser
