Using Signal on PinePhone in mid-2023?
#31
(06-23-2023, 07:39 AM)dante404 Wrote:
(06-21-2023, 09:32 AM)Pelecanus Wrote: Maybe a workaround is to use the signal-cli?:
Yes, would be an option - Better than nothing I guess Wink - Thank you!
(Used signal-cli just on my Linux-Desktop-PC to activate the Client on the PinePhone, so I guess I will have to get it on the PinePhone as well...)
Did you try to receive the pictures on your Desktop PC? Did that work? If it doesn't work either the problem is something else, not Signal on your PinePhone.
(06-23-2023, 09:47 AM)shulamy Wrote: i have to check it - next week
ezik
Thank you! Smile
(06-23-2023, 12:33 PM)Pelecanus Wrote: Did you try to receive the pictures on your Desktop PC? Did that work? If it doesn't work either the problem is something else, not Signal on your PinePhone.
Yes, in the Signal-Desktop-App on my Linux-Desktop-PC (Kubuntu) it works, I see sent images there. Hmmm... Huh
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
@zetabeta & @shulamy:
Because it seems not to be a general problem according to Pelecanus - Does your "Signal-Desktop-App on PinePhone" show images someone sent you? Huh
i use x86-64 laptop (with debian/linux) for both signal-cli and signal-desktop-app. both work fine. getAttachment also works, and files are stored locally, assuming command receive has been done.
maybe i test signal-desktop-app in a pinephone, but not immediately.
edit: adding debian/linux laptop
edit: typo
(06-23-2023, 08:12 PM)zetabeta Wrote: i use x86-64 laptop for both signal-cli and signal-desktop-app. both work fine. getAttachment also works, and files are stored locally, assuming command receive has been done.
maybe i test siganl-desktop-app in a pinephone, but not immediately.
Ah, my fault sorry, I got you wrong somehow then. Smile
@picture problem: I also can't sent pictures on my PinePhone (takes forever, nothing happens). Really strange. On PC all is still good, recieving, sending... It's like some other package/framework/... used by Signal is missing on my PinePhone/Mobian, but I don't know what it is.
@dante404 Did you see this issue?: Since 6.19.0 I am not able to handle images and attached files
It seems other people have the same problem with Signal Desktop on ARM. Unfortunately no solution so far.
Edit: there is also some discussion in the Mobian matrix room.
you are right. signal-desktop 6.20.0 gave me blurred picture (in mobian)
i will try to finish signal-fli install and check if it is better
ezik
@Pelecanus & @shulamy :
Ah, thank you very much for the infos! Smile
At least I can stop searching for a problem at my specific install/system now. Wink
Hopefully there will be a solution.
Problem persists in version 6.25.0. No attachments download. No avatars download.
Problem persists in version 6.27. All attachments are downloaded and not rendered. Can not send attachments.
(08-11-2023, 02:21 PM)dragonhospital Wrote: Problem persists in version 6.27.  All attachments are downloaded and not rendered.  Can not send attachments.
it seems that you use desktop app? do you use arm64 or x86-64 version?
i use x86_64 version and desktop app with 6.28.0 version and attachments and images work fine.
  asterisk or FreePBX on pinephone? vanja 0 967 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 25,788 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,281 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 249,235 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 235,933 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,463 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,832 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 72,934 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,286 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 83,053 07-26-2024, 10:35 PM
