How to choose which Waydroid Apps can appear on PostmaketOS Home Screen?
Hello, is it possible to choose which apps installed on Waydroid can appear on the home screen of PostmaketOS Phosh.
By default "Waydroid" integrates many applications: such as the "clock" or the "camera" which are useless, because (for the most part) already present natively in PostmaketOS. So there are many duplicate apps which makes using the home screen chaotic.
Thanks in advance  Smile
PS: I've already disabled the "unwanted" apps using the "Waydroid" settings, which made them "disappear" from the Waydroid home screen, but had no effect on the PostmarketOS one.
(05-12-2023, 04:24 AM)Avisando Wrote: Hello, is it possible to choose which apps installed on Waydroid can appear on the home screen of PostmaketOS Phosh.
you can try deleting them from ~/.local/share/applications or as suggested in mobian wiki (https://wiki.mobian-project.org/doku.php?id=waydroid) leave them in place and truncate to 0 length e.g. truncate -s 0 ~/.local/share/applications/waydroid.com.android.calculator2.desktop
I guess first approach might work if you have disabled the apps in waydroid, but otherwise it would get recreated next time you restart the waydroid. Truncating seems like more universal solution, not requiring any other steps.
Setting NoDisplay=true or even Hidden=true would likely also work and be less of a hack than truncating to 0 size.
(05-24-2023, 07:57 AM)archon Wrote: Hello,
Thank you very much, I tried the Truncating method and it works very well!
The apps (listed in the mobian wiki ) really disappear (even after a restart).  Smile
(05-24-2023, 08:09 PM)Kevin Kofler Wrote: Setting NoDisplay=true or even Hidden=true would likely also work and be less of a hack than truncating to 0 size.
Your method is very effective and works with all apps!
Thank you so much Smile
By the way, the difference between NoDisplay and Hidden is that NoDisplay only visually hides the .desktop file, Hidden completely disables it, so that it is also not considered, e.g., for file associations.
(05-27-2023, 11:53 PM)Kevin Kofler Wrote: By the way, the difference between NoDisplay and Hidden is that NoDisplay only visually hides the .desktop file, Hidden completely disables it, so that it is also not considered, e.g., for file associations.
Thank you for that clarification Smile
  Unable to set default apps Barugon 7 9,985 12-04-2022, 12:28 PM
Last Post: alaraajavamma
  Video not playing in waydroid catalyst 1 5,088 09-16-2022, 02:58 AM
Last Post: olyavi
  Help with ssh and setting default apps jojuma 2 5,948 09-10-2022, 07:55 AM
Last Post: jojuma
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 6,365 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Waydroid feklee 4 12,906 04-27-2022, 06:04 PM
Last Post: tk1107
  closing apps rather than leaving them running (phosh) lordearl 7 14,731 02-03-2022, 09:14 PM
Last Post: parry
  pinephone boots to green screen after running out of space costava 1 3,703 01-30-2022, 06:29 AM
Last Post: costava
  Resize apps for postmarket OS zeb11 8 18,740 09-26-2020, 04:21 PM
Last Post: ragreenburg
  Touch Screen Not Turning Off Skin 2 5,559 09-24-2020, 02:08 PM
Last Post: jmorris
  Adding a program to home screen. pcdoodle 1 5,437 08-12-2020, 12:02 AM
Last Post: Boern
